As far as I know it's a VR, (variable reluctance) sensor and works on the output shaft
with a toothed wheel in the box, the same way a abs sensor works on the CV joint.
I don't know how many pulses/ teeth per rev it has but I suppose it could be measured.
Maybe someone with in depth knowledge of the ECU may know.
So as it is located on the front diff on the 01E, likely the sensor picks up an impulse from a tooth or teeth on the front diff.
It would be useful if anyone knows the number of impulses per rotation, or how to measure that?
I guess so, I'm yet to take the diff cover off a gearbox to find out. I am surprised that a reed switch is reliable enough, but they never seem to go wrong...
Can anyone tell me some info about the G68 vehicle speed sensor? Specifically, what type of sensor it is, how it works and how many impulses per wheel rotation / per mile/km? Thanks Alex
It generates impulses as the teeth on Item 8 pass the nose of the G68 sensor:
I knew you'd have some info tucked away Dave. Good picture showing the guts of the thing. so it is just a boggo reed switch.
That Item 8 "speedo drive" must have magentic tips on the teeth then?
I knew you'd have some info tucked away Dave. Good picture showing the guts of the thing. so it is just a boggo reed switch. That Item 8 "speedo drive" must have magentic tips on the teeth then?
Good insight on the magnets.
I just searched on 012409187C, the drive gear and came up with these two diagrams (that I will be adding to my G68 post - thanks for prompting me to add more info )
Tranlation of the German, not perfect but you get the idea:
How it Works
In the tacho-wheel is a 4 pole paired connectors that provide interfaces, ferrite magnet molded, there are alternately 4 North and 4 south pole in a row. The tacho-wheel is rotated so that individual magnetic field on the Reed-contact effect, is closed. As soon as the interfaces between north and south pole to the reed-contact aligned south, opens the contact.
This process is repeated per revolution of the tacho-wheel 8 times. The speed of the Tacho-Gebers reaches the electronics of the speedometer and is the speed and distance with the help of a IC and a stepper motor processed and reinforced.
Reed-contact
The reed-contact is a tongue contact. It is for the protection against pollution, moisture and corrosion in a gas-tight glass melted down. In the glass tube is located a shielding gas. The closing and opening the contact is made by magnetic force.
