S2Forum - The Audi S2 Community
Go Back   S2Forum - The Audi S2 Community > Technical > Aftermarket Engine Management
Reply
Thread Tools Display Modes
Unread 09-04-12, 01:26 PM   #1
madpugger
Scotland
madpugger's Avatar
Garage
VEMS WBO2 calibration
Guys, having a bit of an issue here.
I am trying to do a fresh air test on my WB02 and the max I can show is 16.1%
I have tried two sensors and both are giving the same result. Any ideas?
madpugger is offline   Post Tools
Unread 09-04-12, 02:04 PM   #2
QuattroFever
Home Country - England
QuattroFever's Avatar
very interesting...what firmware are you using?
I have had the same trouble. Think i got 18% max but verified with a lambda setup on the RR everything is ok.
Absolutely not saying that yours is ok to go and thrash btw but mine was just giving a false reading at calibration. I'm on 1.1.81 there are newer versions that maybe might solve it but I've never bothered.
__________________
Happy...for now!
Ant
QuattroFever is offline   Post Tools
Unread 09-04-12, 02:06 PM   #3
madpugger
Scotland
madpugger's Avatar
Garage
I'm on 1.1.81 also
I had this issue before and all of a sudden it worked. No idea how I fixed it before but it obviously wasn't fixed properly!
Unread 09-04-12, 02:20 PM   #4
QuattroFever
also i dloaded and installed the latest version of vemstune a few weeks ago after having probs with the gauges moving from saved locations on start up and haven't treied recalibrating since. i was using a release from last summer I think. Software maybe got corrupt somehow but seems ok since so maybe solved other things as well.
__________________
Happy...for now!
Ant
Unread 09-04-12, 02:38 PM   #5
madpugger
Scotland
madpugger's Avatar
Garage
I'm on a build from November, think its the latest propane.
I am running windows 8 but everything works fine. I can change values and see a result but at 255 I only see 16.1. I thought my sensor was contaminated from the engine letting go but a brand new one gives exactly the same results.
Unread 10-04-12, 09:05 AM   #6
madpugger
Scotland
madpugger's Avatar
Garage
Still confused by this!
Are there any other settings to look at?
Unread 10-04-12, 12:15 PM   #7
QuattroFever
Calibration procedure for controller.
http://www.vems.hu/wiki/index.php?pa...ndHardwareTest
__________________
Happy...for now!
Ant
Unread 10-04-12, 01:55 PM   #8
popdemonic
Thailand
I have had the same issue before with the used WBO2.I tried to calibrate until the number is maex out.No worky.Finally,got the new WBO2.It's fine.
__________________
1995 UrS6 Thailand
Manual box conversion.
GT2871.
Wagner 'EM.
VEMs.
Dr.Schrick Cams.
BBS LM.
Cayenne Brake.
popdemonic is offline   Post Tools
Unread 14-04-12, 02:40 PM   #9
miljan
Bosnia and Herzegovina
miljan's Avatar
Garage
I had the identical problem. I put the probe on the exhaust, then got ground and it worked great.
miljan is offline   Post Tools
Unread 14-04-12, 06:28 PM   #10
Billman
Billman's Avatar
I think it has to do with residual fuel on a used sensor.
__________________
Go Holset or Go RS4
Billman is offline   Post Tools
Unread 14-04-12, 08:12 PM   #11
madpugger
Scotland
madpugger's Avatar
Garage
I have tried with an old sensor and a brand new one though, and they both give exactly the same reading 255 = 16.1% O2
Unread 14-04-12, 09:41 PM   #12
Billman
Billman's Avatar
Check again the connection of the WB sensor? Did it work before? If the sensor is new, the connection / 12+ supply is good etc. and still has issues maybe the controller inside VEMS is defective.
__________________
Go Holset or Go RS4
Unread 15-04-12, 06:10 AM   #13
Jonas_R
Denmark
Jonas_R's Avatar
Where do you get power to the wb sensor?
I had this problem and was using the old lambda plug for power. But the problem is that the lambda wont have 12v unless the engine is startet. Maybe thatbis your issue?
Jonas_R is offline   Post Tools
Unread 15-04-12, 11:43 AM   #14
dkw_dude
Norway
dkw_dude's Avatar
Garage
Same experience here. WB powered via fuelpump relay so had to pull out the FP relay, hardwire lambda power connections and then calibrate the WB sensor after I had removed it from the downpipe, exposing it to free air.
__________________
Leif-Helge
-91 S2 VEMS'ed and RS2'ed (E75 winter booze mode)
-00 A6 tq Avant "S2 parts transporter, and daily driver"
dkw_dude is offline   Post Tools
Unread 02-05-12, 11:29 AM   #15
ian4455
England
ian4455's Avatar
Garage
My WBo2 reads 20 no matter what value i enter in VEMS calibration ? haven't checked for +12 from the inline fuse powered from VEMS but assuming its there can these sensors be cleaned or checked for an output ??
ian4455 is offline   Post Tools
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Powered by vBulletin® Version 3.7.0
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
DTO Garage vBulletin Plugins by Drive Thru Online, Inc.
©2003-2009 S2forum.com. All Rights Reserved.
