Please check the last page for the current list
S2 Parts list, LOTS more to follow
Originally posted by Jonnybravo View PostABY, all parts were removed from ABY cars, I should of mentioned that at the start !
They are only £235.00 New...
I would be interested but not at that price...
Originally posted by Jonnybravo View PostMake me an offer then mate, being fair they are as good as new, unmarked, posted for £200, the price you quoted is also plus postage.
If they were anything but perfect I wouldn't be asking so much for them but they were purchased from Roose Motorsport in August last year.
But postage is only £7.00 & £235.00 = £242.00 Not a massive deal!!
Unmarked is not UN-USED & they look like they have been fitted & used...
I'll make you an offer by PM...
Sorry to come across like a real PITA!!
Just looking for a good deal & Money is Tight!!!!
Fair enough mate, money is tight for everyone at the moment including myself so I won't be giving things away that I feel are worth what I'm asking.
If someone wants several bits then maybe I would be up for a deal but from breaking the last one people respected the prices and I had very few issues with any of the prices. Money off at the end of the day is discount, if it was something that had worn out because of use then I could understand but in this case these are as new condition and nearly £50 less than your going to get a set from Roose, plus I would assume they might not even carry them in stock which can be a problem with silicone hose kits.
Either way PM the offer and I'll see what I think.
UPDATED 19.01.10
ABY 6 speed gearbox, smooth gearchanging, has a whining noise which has been diagnosed by a Audi technician as the diff bearings, supplied with no mounts or linkage £200
Bailey Re-Circulating dump valve anodised in Blue, slight scuff on one side but cosmetic only. £60
Alloy re-circ dump valve, unknown manufacturer but works perfectly, like new condition. £45
Ecu mount, mint condition, 3 available £10 each
Metal intake hardpipe, 2 available £10 each
ABY Ecu, Homefrys chipset, supplied by Paul £350
ABY Air Mass Meter, 3 available, all perfect £40 each
ABY Lambda sensor, non genuine, few k old, £25
ABY Lambda sensor, genuine Audi, few k old, £40
Sport 3 Spoke steering wheel, complete with boss and surround £75
ABY Air box, perfect, no cuts £25
K&N Panel filter, needs a clean but otherwise perfect £15
POS's x 4 £30 each
