Biturbo's Audi S2
  • Biturbo's Audi S2
    Ok will show my project.Car is Audi S2 coupe 1995/12 ABY laser red.I bought this car for drag race and some track days.Target is make 10s car with over 600 bhp.With standard engine I did 12.81s in santapod.With same engine but on vems I did 12.69s and that run broke cj joint.Now engine is modified so this is mod list:
    Pistons original modified with new rings
    Scat rods
    ARP head studs
    Head ported
    Ferrera 6000 titanium valves
    Stronger valves springs
    Titanium valve spring retainer
    7A cams
    Engine full balanced
    Clutch:7A flyweel (lighted and balanced), kevlar disc from clutchnet,sach race pressureplate.
    Solid engine and gerbox mounts made by my
    Vems ecu by Kamuto
    Turbo Holset H1E (40) T3 flange V-band and is stamped 12 in Exhaust side.
    Tail 44 copy wg
    Boch 040 pump in original tank
    Siemens deka 835 (3bar) injectors
    Intake aan
    Very big IC with 3" piping
    This is some foto:
    And today I start first time my car after engine all this mods.
    How is the build coming along?
      Car is finished.I'm maping it on the road and saturday first test in santa pod.I was scary of it on 0.6bar first time
        Your dry out of fuel with one pump in the stock tank
        Chef
          More exactly - the 040 is not sufficient, AFAIK the 044 flows quite a bit more at high boost.
          A 044 in stock tank with a relay, will support 700 flywheel hp and I am pretty sure OP will not really make more than that.
          I have not tested the 040 that much personally. Maximum I've run on one was 450hp.
            On methanol no
              And I still need do adjustments,is going too rich.Saturday I will go on 1bar only.
                Originally posted by Biturbo View Post
                On methanol no
                If you are going to run methanol as fuel, then as I understand it you actually need to more than double your fuel delivery as the energy density is much lower.
                If you mean that you are running methanol injection - then this is not really relevant at all, as the majority of fuel comes from the injectors, and you will max out the pump on gasoline.
                Either way, a fuel pressure gauge would be very much recommended.
                  As Pri said you have this alittle wrong.
                  And i agreed with him you need twice as much Methanol than petrol as the stioch is something like 7:1-9:1
                  Chef
                    methanol needs at least double and if not a nuclear meltdown will occur
                    040 pump will like PRJ says do 450bhp and thats on normal petrol . if your running methanol for 600 bhp you will need at leat 1600cc injectors. otherwise it will not run. you also have to drain the tank and pipes every time you use the car and start it on petrol till its warm then swap it over.
                      Methanol injection.My target 600+ and will change feul tank later by racing ruls.Gauge is on the way.Thanks for advise
                        Fuel tank is fine, your fuel pump is not. The bare minimum for your power target is a 044 with a relay feeding directly from the battery. I have a few 600+ cars running like this and the fuel pressure is solid.
                        Unrelayed 044 will hit fuel starvation around 500-550bhp depending of course on the condition of the pump electrical lines. This is from my experience.
                          ah ok but your pump is still too small for 600bhp safe. be very carful between 6500rpm-8000rpm thats where it will run lean in3rd4th5th6th etc
                            I turning boost very slow and always cheking all thing on logs and driving.If I will see that is going too lean will put one more 044 pump external.Thanks Will for piston rings
                              Make sure you diagnose the fuel pump correctly and not try to add fuel.
                              The best way to notice it is the fuel pressure tapering is if you are adding fuel but it does not want to go richer anymore and you start to max the injectors.
                              Good luck, and make sure to drive with the headphones on... One bad pull with high boost and fuel going lean can mean a melted engine at this power.
