80q b4 2.2 20vt project
  • 80q b4 2.2 20vt project
    I decide to make a own thread for this car, so the UrS4 project thread stays simpple. So I bought a b4 80 quattro which has been a 2.8 V6 orginally, it's just a rolling chassis without engine, but it has everything else. Previous owner, Mehtala, did first made a 1.8T swap, but later on did a AAN swap on it, so it has full AAN loom, just PnP. Sure 1.8T is cool, but 2.2T is just avesome, so I think he did just right there. Also big thanks to him, because the price was just really friendly.
    Anyway he also did many other things to it, like deleted the hydraulics and put in a Opel/Vauxhall Corsa C electric steering column. Also brakes got updated, calipers are stock, rears are new though, but the servo and master cylinder are from an A8. Battery is re-located to the trunk. Here is the specs that was made on the car when I brought it home.
    - Full AAN engine loom with build in TFSI coil connectors
    - Front radiator
    - A8 brake servo and cylinder
    - Corsa C electric steering column with adjustable assistance
    - 4:11 ratio front and rear diff
    - Torsen mod (more force to the rear)
    - Aluminium front subframe bushings
    - 2,5" exhaust
    - 550x140x65mm FMIC
    - Battery in the trunk
    - Lowering springs
    - AnLe poly engine mounts
    - AnLe poly transmission mounts
    Also got a "RS4 style" tuning bumper from PKK member Teemu that he has had laying alround for a while. Don't sure about the look, but anyway the clear corners and fogs would be good.
    The plan is to make a "getto" AAN engine with maybe HX35 Super size turbo and maybe 450-500hp. Not more as the 01A transmission may not tolerate much more. Anyway this will not go so far as the UrS4, I will keep this simpple and as an everyday user and nice winter toy. Not trying to build any RS2 sedan replica... naah...
    wow 2 threads from Thuppu, i wasn't wishing that much here
    Audi S6 C4 2.2T Quattro 1997, full rebuild....
    Audi A5 Sportback V6 2.7 TDI 2011
    Volkswagen Phaeton V6 3.0 TDI 2009
      i think you have to much time
      I will follow this closely like your other project
      TWINCHARGED power,zero lag
      AEM W/M injection
        Well, this won't be updated as much as the UrS4 thread, will just make the engine and MOT it and register it with the new engine. I have almost all engine parts ready. Missing only turbo, fuel rail, injectors, throttle body, IAT sensor, DP, and the software for my AAN ECU. Already bought PLX DM-6 Gen4 wideband gauge with LSU4.9, was a good deal for an hour.
          Nick. UrS would be finished a long time ago if enough time.
            Nice! Do you have some more photo how the electric steering column is connected to the steering box?
              No sorry, I don't have more photos of it. If Mehtala reads this he maybe can post some pics..?
                Best engine and transmission mounts on market. Superstiff but no metal to metal contact.
                  Where did you get those? I need something good for my urs6 also.
                  Because once turbo met with the bonnet.. Don't want it to happen again.
                    Finnish member AnLe makes them: http://www.s2forum.com/forum/showthread.php?t=79243
                      Thanks Thomas!
                        Got these today. Vems came with a LCD so I'll guess the PLX is little bit unnecessary. I may sell it....
                          Turbo arranged. I have no idea how it will work..? It's not anything common with these engines, it's a custom Garrett/Compturbo with 54/76mm compressor and 62/74mm turbine wheel. Turbine housing is a small A/R .48. Hope to get ~450-500hp with decent spool <3500rpm, but as usual, goes maybe not as planned.
                            Interesting turbo Thomas.
                            Sent from my LG-H955 using Tapatalk
                              Haha, Des, your EFR would have been perfect for this car, but missed that deal.
