Clutch release / throw out bearing
  • Clutch release / throw out bearing
    What are the thoughts on the plastic and metal versions of these? I replaced mine a few years back with a plastic version from VAG but as I'm looking at replacing the clutch with an uprated one, I wanted to fit a new one to be safe... as ever
    I can get a Sachs one with the clutch kit but it looks to be the plastic version...
    http://www.sachsperformance.com/Sach...utch::696.html
    Where can I get a metal one in the UK?
    http://www.034motorsport.com/engine-...01e-p-543.html
    Here's the metal one from 034 but is there a UK alternative?
      I think you will find a few threads on failed OEM release bearing, go with sach
      Think you get the picture
      RS 2 580HP
        Sachs one looks the same as OE though hence the thread...
          plastics no issue so long as its well designed and thwe stress is placed against materials up for the job.
          naturally we prefer metal feeling its "stronger"
          just do the engine upgrades and run it andy. you know your stuff and really to extract 500HP or so needs not many special bits on the I5. the specials cost lots and give little at sub 600hp levels.
          longevity over strength is key if using it regular.
            I would not risk it, its a bitch of a job if it fails and the after-market ones are not dare
            RS 2 580HP
              if oem is bad and its the same as andy suggests where do you go?
              its not about risking it with a 2 quid part. its about sach v oem. if the same not a problem.
              personally id go oem as I did on most of my build parts but if that's the same as sach then why not get the full lot there.
                I'm running one i sourced from 034, but in all honesty there is nothing wrong with the original plastic one so dont bother with it.
                I remember Jamo always gave out about the metal ones rattling, not had the issue myself but i suspect with 3B single mass flywheel conversions they have more room to move about.
                91CQ20v - Gone to a new home
                93UR-S4 - The Magic Carpet
                94S2Bus - The Emerald Express
                  I would only use OE/Sachs/Luk but remembered seeing the metal 034 one and wanted to know if it was a readily available part in the UK, as plastic goes brittle over time, as proven on the water and oil systems...
                    I've had both Audi and Sachs and they are the same, the plastic body does not appear to be a problem but the face plate wears away very quickly and then falls off. I'll post some pics in a bit.
                    I ordered an LUK one from ECP when I did the flywheel pin the other week, when I went to collect it it was not an LUK but it did have a metal face plate. Seems OK so far, it was about £25.
                      Will know how good the OE one is when I take it out, it had a hard life till I went RS2 and became all scared about launching it
                        Found it here http://www.ebay.co.uk/itm/New-AUDI-V...item58a0e85132 but no hint as to who made it. Lucas/Girling do make bearings for a variety of vw/audi cars, i suspect it may be one of them.
                          There's a metal one on the Helix clutch website -
                          http://www.performanceclutch.co.uk/c...437-708278.php
                          Also, from their online parts catalogue, the LUK number is 500 1050 10 - £18 http://www.bestpartstore.co.uk/623872
                          There's also the LUK 500 0607 20 but that's £58 - http://www.bestpartstore.co.uk/630181
                          ^^ This appears to be NLA and has been superseded twice
                          SKF part number VKC 2601 - £13 http://www.bestpartstore.co.uk/17112
                            This is the one that came with the SRE clutch kit. This one had done about 1800miles when the exhaust valve broke and I had to take the engine out again, I replaced it with an Audi part. As you can see it's already wearing a healthy groove in the face plate.
                            This is the Audi bearing
                            This one had done about 8000miles, as you can see it's gone through the face plastic face plate and it's now doing nothing. There is also a lot of side to side movement in the bearing itself considering the mileage. Didn't get a picture of the metal one I fitted replaced it with.
                              Interesting, any i have seen had grabbed onto the fingers and stayed in the one position.
