I have this current setup and think the RS2 FARB is not really required if you don't mind the car being more rear biased. The RS2 FARB makes it a bit more neutral if with a little tendency to understeer.
For a stock or mapped S2, standard front is fine but I prefer the RS2 FARB with RS2 spec power levels
As above, what I'd do Jase is pick up an s2 bar for cheap as its bigger than the cq 10v or 20v one anyway so will be a slight improvement, it's the rear bar that's going to make the most difference. And stiffening up the front will just make the car more understeer prone. If you want to stiffen the front up properly you should knock some coilovers together.
I am intending to fit something like KW v3, I so far have - solid subframe mounts, track hardness wishbone bushes, solid top mounts, poly gearbox mounts. I also don't know if the vr6 will make a positive or negative impact on the handling. I am hoping it will be an improvement as its shorter than the I5 (but possibly heavier).
On a Coupe I'd use the S2 bar with bigger rear and leave it at that, the RS2 bar has more of an effect on the handling on the Avants. Thats what I found between the two body types.
Yes that would be the best combo to start with, the car will be more snappy that way, adding the rs2 bar with the whiteline does make the car very neutral as it does induce more front understeer by itself but the whiteline cancels that, where as rear with s2 front gives a little oversteer if pushed
thats how id like it to be honest! Cheers,
need to find an S2 breaking as i still need driveshafts and a prop.
As it's a B3, have you upgraded to B4 struts with the longer drop links, rather than the B3 stubby drop link setup?
From experience, I'd recommend S2 26mm front and then B4 24mm front on the back or 25mm (as I have) on the back if you want it more aggressive.
Ideally, you'd stiffen the rear with springs (coilovers only) and then run a whiteline adjustable but if you don't have coilovers, then that adds to the budget somewhat.
Good things with stock bars is that they're cheap and readily available.
If you do have the B3 style bar, then you could do as Error404 did and run that on the back
There's a sticky thread with all the details on the FARB on the rear for a coupe
