... Ok guys... how the hell do you fit the poly anti roll bar bushes? The hole in the bush is round and the ends of the arb's are not.... Is it a case of grease it up and give it a good whack??? (Wow, the amount of times I have greased it up and given it a good whack... but im getting side tracked now)
Not that ive noticed Eric but if there isnt one I will make one... They are Powerflex ones, the same as the one in your picture. Im sure a stanley knife will sort the issue out for me.
I just had a look at my set for the avant, and they dont have the split. So I think I am wrong.
You just slide them over the ends over the arb., I just did it just now. Mine were 26mm.
Umm I will need to check when i get home later... I hope I got the right ones if not it looks like a journey back to the supplier and getting the correct ones...
You need 28mm ones then, you sure that's what you got mate?
I think thats the front one bud isnt it? I think the rear ones are 16mm? The Powerflex website only lists up to 16mm anyway... I already had a set a friend got me as a gift that dont fit which are the ones ive been trying. I think they are a 15mm though....
