Ball joints for cast wishbones.
  • Ball joints for cast wishbones.
    I have a pair of cast wishbones as below, I need ball joints before I can fit them obviously! They're going on my 7A B3 CQ
    Have looked through one of the "sticky" posts where I was hoping to get part numbers but to no avail.
    Can anyone give me some advice please........
    Cheers.
    John.
    This should help John
    1995 Audi S2 Avant
      Hope this helps:
      http://www.s2forum.com/forum/showthr...l+joint+forged
        Thanks guys, will try and get a hold of TRW joints........and likely some standard Audi bushes as it's poly on them just now although I might just fit them as they are as the subframe will be off for refurbishment later in the year.
        Will get new press-fit bolts as well.
        Thanks again.
        John.
          Pete Reeve does the Ball joints and definitely stick with with polys
            Get TRW ones, they're the OE manufacturer. I just got a pair for about ÂŁ60 total from MisterAuto I think.
              I had a pair of B3 ones that came with my arms. Not sure if I threw them out last week...
                I always get my suspension components from Lemforder - https://webcat.zf.com/ (change the language to English at the bottom) - and just googled the part number to find a supplier. Eurocarparts can get any ZF/Lemforder product.
                  I used lemforder on mine when I changed last too
                    Thanks, regardless of if it's Lemforder or TRW will the joint fit the CQ hub carrier?
                    To reiterate it's a 7A CQ of the B3 variety and not an S2.
                    Thanks.
                      Yes except the hubs themselves, CQ20v hardware is the same as the 3B
                        That's a big 10 four !!
                        Cheers.
                        John.
                          Actually not all ball joints are the same. You want the later spec ones as they offer a bit more castor. Not sure if Lemforder do both but TRW definitely do. Search for a thread I did recently, as there are TRW part numbers in there.
