PID settings for dynamic boost control
  • PID settings for dynamic boost control
    Link ECU, otherwise stock RS2
    Not sure if there is any equivalent in VEMS or motronic but if so can anyone shed some light on what works best for the RS2? Does motronic use 3 stage boost control? Gear dependent N75 duty cycles?
    Screen shot below shows the PID setup page on the Link interface. These are recommended 'starter' settings and are considered very soft.
    If you want some context, here is a link to the Link ECU closed loop boost control setup guide:
    http://www.linkecu.com/dealers-only-...%20Control.pdf
    Thanks in advance
    Vems has similar setup. Start with what you have and then play with more agressive gain or p.
      with link ive always used an external boost controller.
      no reason the link shouldn't work. controllers are easy to achieve what you require though in general.
        Didn't link have a base WGDC map? I think it did. Been a bit since I last played with one.
        Turn the PID off first and run fixed DC.
        Set the fixed DC so it runs well with it.
        After that's done, disable I and D, set P so that the boost softly oscillates around the target through the revrange.
        Now add I until the oscillation mostly goes away.
        Finally, do some spoolup runs, and note the overshoot. Add D until the overshoot mostly goes away.
        The boost pid is about the LAST thing to tune. For all the general timing, fueling etc tuning use fixed DC and vary it to hit different load cells. Only after that all is done tune the boost PID.
        Good luck.
          Thanks guys. Yes link does have a WGDC map.
            Good luck.
            Shortest, clearest and best advice for tuning boost I have seen so far.
            '96 UrS6 auto PRJ chipped E85
            '95 80Q AEB VEMS E85
              This Dmitri's explanation was very helpfull when trying to undertand Vems boost control. I think Vems FAQ is very confusing. Lots and lots of details and words, but in the end no real life description of how to make the settings. Go it sorted out with these instructions. But I was quite suprised of how simpple it was to set the PID with 4-port MAC valve. Ended up with settings 2-0-0 and have perfectly stable 2bar boost with no overshoot.
