S2 ABY RH Drive Hydraulic to Vaccum servo conversion
  • S2 ABY RH Drive Hydraulic to Vaccum servo conversion
    Has this been done on a Coupe S2 ABY right hand drive? what parts are needed and is the conversion better performing than the OEM brake bomb.
    I am looking at replace my bomb but they seem expensive and from what I read tend to fail quite often.
    Febi are asking R4800 for a new one. About 301 euro
    orsum
    I did this. The fuel lines are the only snag, the rest is simple. Performance is not really any different, it more that parts are £250 new not £1500...
      Can't have searched
      http://www.s2forum.com/forum/showthr...ghlight=vacuum
        I did search but it only came up with the LHD version.
        Must be doing something wrong.
        Thanks for the help
        orsum
          No worries, was only joking
            All good.
            Rusty from what I read all that is needed is a servo, bracket and seal. And moving pipe lines.
            Body mods are needed.
            Is that correct?
            orsum
              And a modified pump to get rid of the high pressure side but this can be as simple as removing the spring under the x plug.
              That's about it, yes. You'll want some plumbing for the vacuum and the clevis pin may be different between ABY and vac as I think it's a bigger thread on the ABY.
                I am a bit concerned about the body work mods.
                Any welding/heat needed or is it a straight forward cut, drill and repaint.
                orsum
                  You will have to cut out that brace / bracket on the strut tower so some light grinding & a touch-up will be required afterwards.
                  Get in touch with me if you need a genuine drop-in rebuilt pump
                    I did mine with a hacksaw and Dremmel, so it's as simple as cutting the body gets
                    Just need a smaller angle grinder, as access is a little difficult for anything too big and once it's all out, just finish, primer & paint.
