Guys I've been permitted to login to Tradition, but even though I'm back on I cannot seem to find the front wheel bearings for the beast? I have this part number 893498625E anyone shed any light as to where best to acquire some please??
Front Wheel Bearings RS2
Originally posted by fourwh33ldriv3 View PostGuys I've been permitted to login to Tradition, but even though I'm back on I cannot seem to find the front wheel bearings for the beast? I have this part number 893498625E anyone shed any light as to where best to acquire some please??
Here is one alternative UK source that you could check out.
http://www.volkspares.co.uk/view/whe...c53003728c1db9
Originally posted by UrS4boy View Post893498625E is the wheel bearing kit which means it contains the wheel bearing you need plus the bolts and nuts that should be replaced. The kit is for all B3 and B4 Audis including the cabriolet, not just the RS2. Should be a dealer stocked item, not an Audi Tradition source. Try Pete at quattro Corners too.
1998 A6 Q (Suzie)
2 x B4 80's both 1993 (Heather & Hazel)
1995 A4 1.6 (Heather II)
1999 A6 Avant 2.4 (Bollie)
2001 S6 Avant 4.2 (Rio)
1995 80 Cabrio 2.6 (Gracie)
2013 Q7 Flooded & gone
1995 RS2 2.2 Flooded & gone
Originally posted by Pauliusb2 View PostEbay is not guaranted quallity, i work for motorfactor and i get my fag bearings straight from fag direct so its 100% genuine fag bearing
Originally posted by UrS4boy View Post893498625E is the wheel bearing kit which means it contains the wheel bearing you need plus the bolts and nuts that should be replaced. The kit is for all B3 and B4 Audis including the cabriolet, not just the RS2. Should be a dealer stocked item, not an Audi Tradition source. Try Pete at quattro Corners too.Be alert! America needs more lerts.
Eric Law
'90 80Q with AAN and Megasquirt
'97 Saab 9000 Aero: mostly stock but ECU tweaks to add fastness
'86 4KTQ: R.I.P.
Originally posted by shaun5 View PostIf it comes in a FAG box has FAG on the bearing, its a FAG bearing in my eyes i know what you are saying but if its advertised as being a certain brand and they send a different brand then surely you complain / reject it.
Tons of counterfeits about, ebay is full of them.
We have had fake SKF bearings at work from their main distributor, they don't know whats in their supply chain half the time. I would expect half the items on ebay to be Chinese counterfeit.... so be careful.
For reference, some p/n from high quality OE manufacturers:
FAG - 713 6101 70
SKF - VKBA 1355
SNR - R157.08Panthero Coupé quattro 20vt
