200 20v turbo avant resurection
  • 200 20v turbo avant resurection
    Just got this!!!
    Some say i am an lunatic... That this car is lost...
    What you think?
    Deserves a second chance?
    i woud strip it and sell the pieces
    TWINCHARGED power,zero lag
    AEM W/M injection
      What pieces? ... Lol!!
        Cant post more pictures at a time..
          What pieces...
            Not really much parts remained....
            Engine has a small hole in the block were the nr. 3 rod came out....
              Soooo!! I need some parts...
              I will make another thread on wanted area for an 200 20v avant lol..
                I'd save it, get the car mechanically spot on and chipped to make the most of the stock K24, leave the body alone but sort the interior and have one hell of a cool sleeper...
                Their rare cars, which I'm sure you now, what's the overall condition of the bodywork like?
                  Bodywork is pretty bad...i mean, some dents, paint, missing trims, bumber..etc...ahhh, the front struts turrets are bent inside...wich is pretty common on these cars on bad roads...but easy fix. I have the hydraulic pusher and i will get an strut brace afterwards.
                  Under..is unbelievable good... really... is virtually NO rust...just dust.
                  even the handbrake is working. The common worn rear camber braces are good. The car has 151478 KM. But totally neglected.
                  Will be quite an challenge...
                    BTW! The car will have an freshly built engine with ABY spec. I have the AAN wiring harness, Homefried ecu. I need a better exhaust manifold...still looking at cheap RS2 replica's, 6 speed gearbox with home made supports. Rest will be stock..
                    At least..this is the plan..
                      200 20v
                      it must be saved ,,
                      we [uk ] only got the 10v , the continentals always got the best kit
                      look forward to seeing the progress.
                        200 20v
                        i would say that my 200 20v with mtm chip set @280 brake is about right[my opinion] for the car as a daily driver.
                          I still think can be saved... as an previous owner of an sedan version of this car...Jessus...i miss'it...
                          What times...
                            I hope i can get the needed parts.
                            I got the hood allready, new, but i need some other...
                              I had a black 100 10v TQ Avant, it was awesome..
