What type of lowering springs to S2 3B will fit?
  • What type of lowering springs to S2 3B will fit?
    So I have a Audi 80 body(B4) and There we did but front axel from S2 coupe.
    One of springs is broken and i need replacment. But its hard to find lowering spring to S2 3B Coupe.
    So question is. Can other springs also fit(B3 or B4 coupe,sedan,avant)?
    Thanks for help!
    Can someone help me?
    Its ok to buy springs or best is coilovers
      hi if you would look there are a few offers in ebay.
      if i was in your place or i would say i will buy coilovers KW v1.
      if you put springs you cant ajust the hight of the ride and moasty the *** is just to high on spirngs and does not look that good.
      http://www.ebay.de/itm/H-R-Tieferleg...wAAOSwXeJXfM28
      http://www.ebay.de/itm/AUDI-80-90-Li...cAAOSwA3dYEKp7
        https://www.n2o-tuning.com/lowtec-pr...-96/a-1370691/
          My problem is that i have front axel from 3B S2 but rear axel is Audi 80 Quattro 1995.
          Therefor i think i cant buy 4 springs sets because axel are diffrent?
          In the future i want to install to rear S2 avant axel and diff. As i readed they are bolt on to sedan.
            I don't think that the front spring for Avant sedan or coupe are different. The rear is the part that differs in coupe from sedan and Avant.
              Hi,
              i have an offer from forum for lowering springs.
              Its from B2 but springs are new and -35mm.
              I thinks thats very good lowering but is B2 springs same as B3 and B4?
