S2central.net not working?
  • S2central.net not working?
    Has anyone access this website or is it down? Is it only me who cant access or is it everyone? Cant find any info regarding this site
    Im in need for some of the wiring diagrams, since my ELSA does not have these older cars. I need to find rpm source from my car to get my corsa steering column to work
    Same problem for me it is like the website doesn't exist.
    I can tell you the rpm wire is blue and green on an s2 if that's any use to you
      I already tried the one wich comes from engine wiring harness, i believe it was lilac wire wich connects to blue/green(?) in dash wiring harness. But result was not what i was hoping, no rpm info in corsa steering column ecu diagnostics and my rpm cluster stopped working when corsa ecu was connected to rpm source
        Will see if Paul is aware
          Any update on this? s2central was best resource for Audi 80 B4 schematics.
            There are some good ones, easier to access, here:
            http://www.s2-audi.co.uk/workshop/sc...schematics.htm
            and here:
            http://www.s2-audi.co.uk/workshop/sc.../sc_lookup.htm
              We're waiting on a copy of the site from Paul and will then be getting it setup alongside the s2forum
                  Good news.
                  "Nulla tenaci invia est via"
                      S2 central
                      Is this ste still down?
                        I haven't heard back from Paul yet. I have been provided a mirror from elsewhere and will look at getting it back online as soon as I can
                          I have an under used re-seller account with Clook if we are short of hosting space for anything http://www.clook.net/
                            Hello
                            If anyone has wiring diagram for AAH engined coupe/80, i would be interested. If possible send to my email jesse.mehtala(at)gmail.com?
                            Im in process of converting my AAH engined cabriolet to newer 30V APR engine and i have few wires missing to make AC and ABS/EDL work like they should.
                            thanks.
                              I have uploaded a mirror of S2central.net to
                              http://www.s2central.com
                              This is fully and entirely Paul's work. If and when Paul returns I will happily give the domain to him.
                              Eric
                              95 S2 Avant under rebuild.
