Retrim headlining avant
  • Retrim headlining avant
    As I've stripped the old headlining material and also removed the old foam and glue I was wondering what had people used for retrimming again , I'm changing color but am unsure what thickness and where to buy from any help would be good cheers
    I used Black foam backed headliner fabric 5mm on ebay when doing mine. Also use the correct glue. I used 3M Super 90.
    Mine:
    http://www.s2forum.com/forum/showpos...&postcount=263
    Eric
    95 S2 Avant under rebuild.
      I've redone mine in grey alcantara type fabric. You can buy it on Ebay with the foam backing already gluid on to it.
      I can recommend buying some extra in the same colour but without the foam backing to trim the A,B and C pillars with.
        Mine:
        Looks fantastic Eric, I did look for it in your pm u sent but couldn't find Which one , I have found some 3mm foam backed material i wanted to make sure it wasn't too thick cheers
          I will do the same too for the a,b and c pillars cheers
            Hi,
            I went thru replacing my headlining a while back and hit a problem with the glue not sticking, its important to keep the board clean and dry, check out the thread called "Headlining Adhesive Problem"
            I used grey alcantara and did all the pillar trims. Its a time consuming job but its worth the effort.
            Good luck.
            PAUL
              I had a quick look on eBay and the seller doesn't sell it any more
              Which ever material you get make sure its 4-way stretch material. Otherwise you could get wrinkles around the tight areas
              Eric
                Originally posted by RS2junkie View Post
                Hi,
                Good luck.
                PAUL
                Cheers Paul I can get some good adhesive
                  Cheers mate il have a look tonight
