I've started to strip the rear hub carrier from RS2replica(wheel bearing fooked)....... got everything loose(bottom bolt marked!) except for the handbrake cable and ABS sensor.
The metal tube on the cable is kinda seized onto the alloy housing which the shoes are pinned to.........have lubed this with release oil and hoping some gentle persuasion with mole grips will free it tomorrow??.......anyone have any input on this?
ABS sensor?.....I'm thinking probably better to disconnect from loom, under back seat yes/no?
Thanks in advance.
John.
Thanks in advance.
John.
