A6 C4 AEL 2wd Fuel Tank Retaining Straps
  • A6 C4 AEL 2wd Fuel Tank Retaining Straps
    A rattle from underneath the car started a couple of days ago and I've managed to have a look this morning. Rather than another exhaust rubber having gone it turns out my front fuel tank retaining strap has rusted through and the tank has dropped down a few inches. Obviously it's not safe to drive the car in this condition so I need a replacement as soon as possible.
    Anybody know if these straps are available new from anywhere or does anyone have a good condition second hand one going spare?
    David
    1994 16v Coupe - Sold on and sadly missed
    1994 S2 Avant - Warmed up a bit
    1995 A6 Avant - Dag Dag Delight
    Last ones I replaced came from TPS. Cheap.
    Would be very easy to fabricate.
    Hth
    Rob..
    94 RS2 Noggy,LHD,MTM map,18"cup 1s,245/35/18,Bilsteins,RS2 H&Rs,Cup splitter.
    87 UR 20v ABY
    97 S6 Avant
    96 A6 C4 2.5 TDI quattro avant,Ming,Wietec/eibach,chipped
    1967 Ford Mustang,Eleanor,460ci v8
      You should be able to make them yourself or somewhere. It's just a strap.
        Hth
        How long ago did you last change them? I would have thought they'd be NLA long ago. I have a local TPS so I'll drop by tomorrow and see if they can get me some.
        Agree they should be easy to fabricate. Even the T section end should just need a tickle with the grinder to get the shape right.
        Thanks chaps.
          Probably three or four years ago.
          Rob..
          87 UR 20v ABY
          97 S6 Avant
            Front strap is 49 +vat
            Rear 109+vat
            Ones they told me how much they are
            I made it my self
            Used 35mmx2mm steel starp
            Just welded original audi ends on them,
            You will see what I mean ones you got old one off
              All sorted. Ordered a new strap from TPS yesterday morning, picked it up this morning and have just finished fitting it. Not a difficult job but getting the car high enough up in the air to get access was fun.
              Must have got a bit of discount as it was £44.74 + vat. Luckily there were two of them in the UK warehouse.
              David
