Bosch OEM part numbers
This is a sticky topic.
  • Bosch OEM part numbers
    I thought it might be useful to have a thread with the OEM part numbers for various things to avoid having to pay through the nose at the dealer - I've started piecing together a list of info and prices - if anyone can add anything or spot any errors please post up
    PART ----------------------- VAG P/N ----------- BOSCH P/N ------ PRICE APPROX
    Altitude Sensor ------------- 853 919 562 --------- 0 280 101 001 -------- £57.46 + VAT
    Crank Position Sensor ------- 034 905 381 --------- HITACHI? RS 101B
    Crank Speed Sensor -------- 034 905 381 A ------- HITACHI? RS 101A
    Lambda Sensor ------------- 034 906 265 F ------- 0 258 003 957 ------- £50.81 + VAT
    Hall Sensor 3B -------------- 034 998 065 --------- 1 237 011 081 -------- £64.74 + VAT
    Hall Sensor ABY ------------ 034 905 161 --------- 0 232 101 020 ------- £64.84 + VAT
    Intake Air Temp Sensor ----- 034 905 379 B ------- HITACHI?
    Knock Sensor - Brown 3B ---- 077 905 377 A ------ 0 261 231 040 ------ £26.91 + VAT
    Knock Sensor - Green 3B ---- 054 905 377 A ------ 0 261 231 038 ------ £22.98 + VAT
    Knock Sensor - Blue ABY ---- 054 905 377 G ------ 0 261 231 036 ------ £22.98 + VAT
    Knock Sensor - Blue ABY ---- 054 905 377 -------- 0 261 231 036 ------ £22.98 + VAT
    Knock Sensor - Green ABY -- 054 905 377 A ------ 0 261 231 038 ------ £22.98 + VAT
    Coolant Temperature -------- 035 919 369 M ----- 0 280 130 037 ------- £10.66 + VAT
    Throttle Valve Pot. 3B ------- 034 133 154 F ----- 0 280 120 410 ------ £50.74 + VAT
    Throttle Valve Pot. ABY ----- 078 133 154 ------- 0 280 120 431 ------- £58.92 + VAT
    MAF 3B / ABY --------------- 034 133 471 K ----- 0 280 213 007 ------ £65.61 + VAT
    MAF ADU ------------------- 034 133 471 N ----- 0 280 213 017 ------ £215.39 + VAT
    Injector 3B ------------------ 034 906 031 ------ 0 280 150 737 ------ £58.12 + VAT
    Injector ABY ---------------- 034 906 031 B ----- 0 280 150 951 ------- £56.10 + VAT
    Injector ADU ---------------- 034 906 031 F ----- 0 280 150 984 ------- £56.10 + VAT
    ISV 3B / ABY ---------------- 034 133 455 B ----- 0 280 140 512 -------- £117.78 + VAT
    Fuel Pump 3B/ABY (and S4/S6)-8A0 906 091 G -----0 580 314 068--------- £69.00 inc VAT
    Brilliant, this makes my life easier here down under
    Everything should be made as simple as possible, but not simpler.--:Albert Einstein
      good work,where were those prices quoted from?
        Got the prices quickly for reference from CES UK who are the closest Bosch agent to me - no doubt some more savings to be had by shopping about a bit
        Theres a loads more stuff I'm trying to piece together too - Pretty much all the electrical connectors & pins you'll ever need, FPRs, Batteries, Alternators, Relays etc etc
          I tried to get some Bosch terminal pins and sealing grommets recently, only sold in bags of 25...darn.
          Stick um up though, maybe a GB?
          Carlos.
          On the look out for less bits for my s2 saloon project. Now supporting myself by shooting for my food. www.airgunforum.co.uk
            A piece from the old yahoo rs2_list for you all:
            RS2 MAF is actually the same Bosch part number "0-280-213-017" as the Porsche 968 MAF.
            > > >Surprisingly enough, this part is cheaper when bought as a Porsche part than as an Audi part. (much higher volume as 968 than RS2). This was helpful when I "RS2-ized" my AAN S4 back in the states and was ableto source the 968 MAF for US$239 shipped to my door!
            > > >If you need RS2 injectors, same thing applies, Bosch "0280 150 984" was also used for one of the 911's, I think it was the 964 RS:.
            Russ
            I found this on the Audi NLA website....a bit confused about the MAF numbers.....
            great find...on the numbers...
              Hmmm. I'm sure it is when bought from Porsche Vs an Audi dealer but not sure it woud matter when buying direct from Bosch?
                ..................do they keep relevant data for AAN?
                  i spent ages cross referencing lots of stuff and also info other poeple have provided - best to check the AAN P/ns against the ABY ones - most of the are probably them same I guess
                  If i've got half an hour later i'll have a look
                    you´re unempolyed huh?
                    One thing i've learned we are way behind the Scandinavians!
                      its Friday afternoon
                        Hey Alex, one to add to the above list.
                        Rusty (Andy) kindly found me the Bosch OEM number for the 3B/ABY (and S4/S6) fuel pump.
                        Audi quoted me £110 inc VAT for this. From Bosch direct it was £69 inc VAT.
                        OEM audi number = 8A0 906 091 G
                        Bosch OEM number = 0 580 314 068.
                        2001 Avus Silver B5 RS4.
                        2004 A4 Avant 1.8T quattro Sport-LE.
                        1995 S2 Coupe - sold (sniff)
                          Added to OP....
                          The Perfectionist
                            Bosch oem part nos
                            Power output stages - 4AO 905 351 A
                            £146.00 Audi Dealers
                            £146.00 Motor Factors
                            £146.00 Bosch (Discontinued ?)
                            Audi S2 Coupe 1995
                            VW Passat GL5 (hatch) 1986
                            VW Passat GL 1.8 (saloon) 1986
                            Carrera Subway 8
                              I think the p/n for that POS is 0 227 100 210
