Go Back   S2Forum - The Audi S2 Community > Technical > Interior
Unread 10-08-09, 11:47 AM   #1
S2central.net
Northern Ireland
How To... Remove the dashboard
Please find this comprehensive guide to this joyful task in the following link... it is honestly not as bad as I thought initially.
http://s2central.net/S2_How_To/Interior/dashboard.pdf
Any comments welcome to improve it further.
S2central.net is offline   Post Tools
Unread 10-08-09, 12:07 PM   #2
Rusty
Moderator
Rusty's Avatar
Good work Paul! What is the level of sound deadening on the dash itself and underneath it?
K24 Racing - K24R Products
Rusty is online now   Post Tools
Unread 10-08-09, 12:14 PM   #3
Error404
Moderator
Error404's Avatar
making sure you park up somewhere you can open both doors fully really helps
how come you've got V6 instrument sin there Paul?
Rusty: not a huge amount really, some of the felt stuff and a few bits of the adhesive pads
Unread 10-08-09, 12:18 PM   #4
dest
England
dest's Avatar
Very little on the actual dash IIRC
dest is offline   Post Tools
Unread 10-08-09, 12:19 PM   #5
lind4hl
Sweden
lind4hl's Avatar
Can you get Passenger airbag out without removing the dash?
One thing i've learned we are way behind the Scandinavians!
lind4hl is offline   Post Tools
Unread 10-08-09, 12:31 PM   #6
Foeglass
Netherlands
Foeglass's Avatar
If i remember correctly, you have to remove the glovebox, and than you will see one torx bolt,
undo the bolt (it's a long one) and than you should be albe to pull the airbagunit out.
Take note that there are 2 plugs in the back of the airbag that need to be unplugged carefully.
"95 Audi S2 Coupé
"02 Audi A8 6.0L W12 Quattro
"01 Audi A8L 6.0L W12 Quattro
"94 Audi Cabriolet 2.8 (in bits 'n pieces)
Foeglass is offline   Post Tools
Unread 10-08-09, 12:33 PM   #7
Error404
Moderator
Error404's Avatar
if you have cruise control, the ECU will be screwed to the dash behind the glove box - needs unplugging before dash can come out
Unread 10-08-09, 12:49 PM   #8
Rusty
Moderator
Rusty's Avatar
Safe init, ta.
Unread 10-08-09, 12:50 PM   #9
S2central.net
Northern Ireland
Didn't take enough photos as I went on the S2... Had to nip out and take some snaps off the V6 dash to complete the guide.
Good point on the doors actually.
Unread 10-08-09, 12:53 PM   #10
S2central.net
Northern Ireland
Also a good point there... should really add that to the guide. If anyone has pics of that and any other photos of how/where the airbags connect that would be good also.
Unread 10-08-09, 01:16 PM   #11
Error404
Moderator
Error404's Avatar
i'll try and get a pic of the CC module under the dash later if i remember
Unread 10-08-09, 09:03 PM   #12
johne
johne's Avatar
Also take the chance to replace/upgrade the front loudspeakers in the dash whilst it's easier with the dash out.
John
johne is offline   Post Tools
Unread 10-08-09, 09:41 PM   #13
S2central.net
Northern Ireland
They'd be easy enough with dash in place unless going up from 10cm diameter - but yes its worth a thought.
Next step for me is to try and identify a lot more of the dreaded wiring plugs on the loom under there and associate them with the schematics - oh joy !
Unread 10-08-09, 10:10 PM   #14
adamw
Shetland Islands
disconect the battery to be on the safe side. especially if it has airbags fitted
cheeRS adam
RS2+
adamw is offline   Post Tools
Unread 10-08-09, 11:17 PM   #15
S2central.net
Northern Ireland
Airbags have a reserve battery, but yes I should add a disclaimer about this for airbag models in case they are especially sensitive.
