Unread 11-01-17, 06:02 PM   #211
M2ki
Estonia
Originally Posted by slazenger View Post
hi.how do you fit the HAA door lock? i've got the HAA conversion kit from a6/c4 and the door lock it's bigger on HAA
Would also like to know.
1989 Audi 80 Quattro
M2ki is offline   Post Tools
Unread 11-01-17, 06:04 PM   #212
Klobsters
Klobsters's Avatar
You need the whole door handle from the A6.
Klobsters is offline   Post Tools
Unread 11-01-17, 06:14 PM   #213
M2ki
Estonia
Thanks for the tip! From what year was the HAA type used on A6.
I was parting 95 A6 one day and it had the old type key.
Unread 11-01-17, 07:02 PM   #214
mdz
Latvia
mdz's Avatar
Originally Posted by Mach.003 View Post
Hi, I could ask for involvement 2000 A6 C5 diesel cluster in B4.
Hi!
You'll need to make adapter harness or swap connector housings arranging wires according to a6 wiring diagram. IIRC '00 A6 had oil temperature/level sender in sump which can't be tricked easily so needs to be connected otherwise check computer will shoe "SENSOR" warning. Also A6 reads fuel tank level opposite way - it will show empty tank when it's full and vice versa This can be solved by modifying cluster firmware or using cluster from B5 A4.
You'll need a handle from A6 too.
Early C4A6 still had old type keys. IIRC it was 1996 when they changed. I got my kit from '96 car.
Updates on car will follow bit later, need to take some more pics.
mdz is online now   Post Tools
Unread 12-01-17, 12:46 AM   #215
macspring
