Unread 14-07-13, 12:32 AM   #46
Pat D
Australia
Pat D's Avatar
I've always thought about fitting a B5 cluster in a B4.
Will it phsically fit in the dashboard without mods?
ABY S2 stroker (work in progress)
B5 1.8T quattro
B4 2.3 (decommissioned)
Pat D is offline   Post Tools
Unread 16-07-13, 08:01 AM   #47
LHD_Kid
Home Country - England Current Country - Belgium
LHD_Kid's Avatar
Originally Posted by mdz View Post
[Button for opening and closing central lock from inside without arming alarm
Could you tell us exactly how you connected this in? Did you simply connect across wires in the door, or did you need to relay it?
Really want to do this, but am an electonic idiot...!!
(I have a door trigger with electric window switch, also a door lock switch from an A3 which fits in the sdame location. Just need to know how to wire it in!)
LHD_Kid is online now   Post Tools
Unread 16-07-13, 04:02 PM   #48
mdz
Latvia
mdz's Avatar
It's very tight but it fits. B5 cluster is ~1cm lower than B4 so it will leave a gap on the top or at the bottom. Gap can be filled with piece of leather or something like that.
Here's a thread about this in Audi forum from Poland http://www.audi80.pl/80-b4-licznik-z...em-vt15687.htm
If your car has central locking, there will be three wires (+12v, ground and one to CL pump) connected to vacuum actuator in drivers door. They are used to lock and unlock doors by pushing in or pulling out rod in front doors. They must be connected to button. I'll be taking off doorcard in next few days and take a picture of how it looks from inside.
mdz is online now   Post Tools
Unread 16-07-13, 04:04 PM   #49
LHD_Kid
LHD_Kid's Avatar
If you can show exactly how it should be connected (illumination and lock functioning) so even an idiot (basically me) could wire it up...that would be fantastic, thanks!!
Unread 16-07-13, 11:29 PM   #50
macspring
Any updates / photos ?
Unread 26-07-13, 06:41 PM   #51
mdz
Latvia
mdz's Avatar
Well, not much done at the moment. I had two week holiday where I was mostly working on other cars than mine. LHD Kid topic inspired me to finish button illumination in drivers door.
And standard grill painted black (chrome doesn't look good with this body color)
Next on the list - battery moving to rear. I missed a chance to get S2 avant battery tray, so I'll be using modified V6 tray. Original strut brace, 26mm FARB (till I find 28mm one) and 5x112 swap.
Allroad vs Noroad
Unread 05-02-14, 12:05 AM   #52
macspring
One of my favourite threads on here.
Any updates ?
Thanks.
Unread 05-02-14, 06:17 AM   #53
mdz
Latvia
mdz's Avatar
Winter sleep
Nothing much done last few months, but at least I now have my own garage.
RS door pull triggers and leg rest from US spec car. I found both US center console parts, but they are dark green so rear part is not installed. I also found oem fire extinguisher bracket that attaches at front of drivers seat, but no picture of it at the moment.
Door lights form C5. They are bit smaller than boot lights used in B4. Bottom ones fits perfectly, red ones has to be modified to fit.
Will take better picture if needed
New exhaust tip, got rid of window tints and 15eur paintjob horrible winter wheels
Battery will be going to rear using modified V6 battery tray
And after a bit of researching, here's whats coming for spring/summer:
5x112 swap with S2 front brake upgrade, polyurethane bushings for front subrame and wishbones, 26mm farb, V6/S2 strut brace and maybe something more to improve handling. Thought about going for aluminium bushes for subframe, but with lowering like mine it will be overkill for daily use on roads like these here. But who knows
Unread 05-02-14, 07:44 AM   #54
_ShurikeN
Russian Federation
Very nice car. We have a guy here in S-Petersburg with FWD ABK B4 saloon. he is not keen on cool turbo-quattro tuning, but his plentiful modest and accurate mods are something the most interesting to look at because of high quality and attention to details.
_ShurikeN is offline   Post Tools
Unread 05-02-14, 08:24 AM   #55
mdz
Latvia
mdz's Avatar
Is it dark green and number plate starts with m999?
Unread 05-02-14, 09:12 AM   #56
_ShurikeN
Russian Federation
Oh, You knew that )
Unread 05-02-14, 09:32 AM   #57
mdz
Latvia
mdz's Avatar
Yep, I'm following his thread @ drive2.ru. Amazing work with interior
Unread 05-02-14, 10:27 AM   #58
Vorsprung durch Technik
Vorsprung durch Technik's Avatar
Thanks.
I never knew this thread existed.
I with Macspring for these reasons.The B3 and B4 are such well put together and good looking cars that they deserve the effort needed to do the fantastic upgrade work @MDZ has done. Stunning attention to detail and work there mate. If i can incorperate some of what you have done interior wise ie,climate and the electrical upgrades i will be a very happy man!!
Vorsprung durch Technik is offline   Post Tools
Unread 05-02-14, 01:55 PM   #59
macspring
Thanks for update fix.
Love the latest changes, including getting rid of the tints.
The rims will look lovely. Which model did they come on, as I presume they are naturally not 5 x 100 from a TT ?
Any more detail on the lights on the inside of the doors. e.g. I presume you had to cut door metal to fit the bottom white one ?
Best wishes.
Unread 05-02-14, 02:09 PM   #60
nimo781
Registered User
All doorcards and A, B, D pillars are retrimmed.
Was that an easy job? I have some black alcantara but not tackled this myself
nimo781 is offline   Post Tools
