Unread 20-07-15, 05:17 PM   #1
maiks
Estonia
maiks's Avatar
Small Urs6 project!
Hello guys!
I'm pretty new here. I bought the urs6, 2.2T almost a year ago and since then I have had a lot of problems with that - gas leaks, lots of air leaks, brakes were stuck and many more. I have got a lot of help here, thats why I am doing my own thread, maybe it will help someone somehow.
maiks is offline   Post Tools
Unread 20-07-15, 05:23 PM   #2
Pirvu Eugen
Romania
Pirvu Eugen's Avatar
Nice car!!! Goodluck with your project!!
Pirvu Eugen is online now   Post Tools
Unread 20-07-15, 05:34 PM   #3
maiks
Estonia
maiks's Avatar
One cylinder had bad compression and I decided to check the valves and same time port the head.
Unread 20-07-15, 05:41 PM   #4
maiks
Estonia
maiks's Avatar
When I removed the head I was not planning to change the the engine belt, because the last owner told he did it 1000 km ago. Then I saw this...
Unread 20-07-15, 05:53 PM   #5
maiks
Estonia
maiks's Avatar
There was also broken original intercooler and everybody here knows that behind the bumper is not enough space, so I decided to put the water to air intercooler but the IAT was a little too high so much money wasted and now I'm waiting for air to air intercooler to arrive...
Unread 20-07-15, 06:19 PM   #6
maiks
Estonia
maiks's Avatar
The 4th gear sync was broken also when I bought the car So i needed to replace it.. When the gearbox was off then I decided to change some more stuff.. No dual mass flywheel needed anymore and the other things all new.
Unread 20-07-15, 06:32 PM   #7
maiks
Estonia
maiks's Avatar
One more weak point removed.
Unread 20-07-15, 07:06 PM   #8
UrS4boy
Canada
Congrats and/or condolences.
So nobody told you about "can of worms"?
UrS4boy is offline   Post Tools
Unread 21-07-15, 11:18 AM   #9
geneandbolly
Home Country - Scotland Current Country - Shetland Islands
geneandbolly's Avatar
yup, been there!!
1997 Audi S6 - The Purple Helmet!
geneandbolly is offline   Post Tools
Unread 21-07-15, 03:07 PM   #10
maiks
Estonia
maiks's Avatar
Lets hope no more worms
Unread 21-07-15, 03:18 PM   #11
maiks
Estonia
maiks's Avatar
Thuppu's rear brake upgrade. Have not driven much so I dont know if the brakes are better, but one thing I know for sure - originals look ridiculous on 18'' wheel..
Unread 22-07-15, 04:57 PM   #12
maiks
Estonia
maiks's Avatar
Last owner wanted to make led lighted gear knob and destroyed the knob.. New 6 speed gear knob was hard to find. So I rebuild the old one with new leather and the hole was replaced with black oak.
Unread 23-07-15, 06:31 PM   #13
maiks
Estonia
maiks's Avatar
Another pandora's box has arrived.
Unread 12-08-15, 05:50 PM   #14
maiks
Estonia
maiks's Avatar
Little work with engine done. New air cooler, turbo, oil lines, Albert's EM, 4'' downpipe, lots of NERVES and oily hands! (bad picture quality because of mobile phone's camera)
Unread 12-08-15, 06:16 PM   #15
UrS4boy
Canada
I applaud your work effort but there are few details that don't look like they are going to work.
1. It looks like you've mounted the mounting bar by bolting INTO the radiator head tanks. That's going to fail one way or the other. Most people hang their C4 FMICs off the rad supports and then tie the bottom to the round frame cross-rail.
Yours:
2. As far as I can see, you will have problems with your left headlight the way you have run that post-intercooler pipe towards the throttle body without going behind the headlight. The photos above and below show how to do it better.
Yours, showing that you cut sheet metal that doesn't have to be cut if the pipe is taken back more first before heading to the throttle body.
