Unread 12-04-16, 06:55 AM   #1
Aandreaaz
Sweden
Aandreaaz's Avatar
Audi UrS4 2.2t project
Hello!
After looking on all others projects, I thought it would be fun to share mine!
I'm already several years into it, so it will be a small summary to begin with.
It is a 1992 Audi S4 2.2t which I bought in 2010 and has kept on upgrading it since.
Driving it on summers and tinkered in the winter.
It was really worn out and in very bad condition when I bought it! Have spent many many hours on it!
It was never meant to be such a big project , but once you get started it's hard to stop
My goal is to keep it nice and clean but at the same time I want to have good performance!
This car is my pride and joy..
I put up some pictures and we'll take it from there..
Removes UFO brakes to S6 brakes
Got hold of a leather interior that I treated , became fairly good
Have changed the gas tank because of corrosion and replace the entire rear suspension to one with a stabilizer bar and also changed every bushing in the entire front and rear suspension, made a huge difference in driving performance
Changed the interior from a worn gray to a black
Repainting March 2012
Mounted Billstein B8 clubsport dampers with custom made H&R springs to match de specification on the dampers, very satisfied with the result
For those who understand Swedish, you will find my projects threads on these links
http://www.garaget.org/forum/viewtopic.php?id=281505
http://www.garaget.org/forum/viewtopic.php?id=280258
2015 Audi A4 Sports edition
1992 Audi S4 2.2t
1986 Audi 80 Quattro
1985 Audi GT Quattro
1966 VW Bug (Herbie replica)
http://www.garaget.org/Andreas90
Aandreaaz is offline   Post Tools
Unread 12-04-16, 08:03 AM   #2
Aandreaaz
Sweden
Aandreaaz's Avatar
Oops, forgot to show the Engine build
AAN ported head, supertech valves, Ina lifters, 7A cams, CrMo valvespring, adjustable camgear
AAN block, 81,5mm JE pistons, 8,5:1 comp, balanced and weighted, H-profil rods, ACL bearings, ARP headbolts,remade crankcasevent with ventilation from 2.5 diesel,
Maxxecu, Precision 1600cc injectors, 2xBosch 044, 1xBosch 040, 2l catchtank, Aeromotive BTR, PTFE hoses, E85, 2.0TFSI coils, custom made fuelrail
Garrett GTX3582r turbo, Tial38 WG, 4" downpipe, 3" exhaust, screempipe from wg
01E CET gearbox, singelmassflywheel, Sachs 707, KEP 6puck sinter clutch
580whp
606nm
1992 Audi S4 2.2t
Unread 12-04-16, 08:11 AM   #3
RichLV
Latvia
RichLV's Avatar
Damn. This is a beast! And looks stunning as well.
RichLV is online now   Post Tools
Unread 12-04-16, 08:21 AM   #4
V6quattro
Netherlands
V6quattro's Avatar
Nice work. What boost do you have @580whp?
V6quattro is online now   Post Tools
Unread 12-04-16, 08:35 AM   #5
Aandreaaz
Sweden
Aandreaaz's Avatar
2.3 bar But the old fuelrail i had was leaking in the dyno, so has not bottomed out the engine yet!
It's two years since I built the engine , but are changing some things on it now, new cams and intake among others. Should get some better numbers this summer hopefully...
1992 Audi S4 2.2t
Unread 12-04-16, 12:37 PM   #6
quattro-nick
Belgium
quattro-nick's Avatar
nice project
audi coupe quattro b2 2.2 20vt project (560hp-600nm)
TWINCHARGED power,zero lag
AEM W/M injection
quattro-nick is offline   Post Tools
Unread 12-04-16, 02:31 PM   #7
DFrosty
United States
DFrosty's Avatar
Bravo sir, well done!
DFrosty is offline   Post Tools
Unread 12-04-16, 04:19 PM   #8
AndyP
England
AndyP's Avatar
Originally Posted by Aandreaaz View Post
What sump did you use when you fitted this from the TDi engine? I'm sure I tried fitting this to mine and the 3B sump would not clear it?
AndyP is offline   Post Tools
Unread 12-04-16, 05:39 PM   #9
Aandreaaz
Sweden
Aandreaaz's Avatar
I use standard AAN sump, just needed to grind a bit on the same side as the ventilation tube is
1992 Audi S4 2.2t
Unread 13-06-16, 12:31 PM   #10
Aandreaaz
Sweden
Aandreaaz's Avatar
Hello!
The last few days have I begun to build the new pressurepipes and intercoolers.
I did not like the old , partly to 2/3 of the intercooler was hidden behind the front bumper without getting any cooling and partly because I want to get on the S6 bumper without having to cut in it.
So it had to be two intercoolers in series...wanted three, but it was too tight towards the turbo in the right wheelhouse and my patience was not enough.
Built in 70mm aluminum pipes.
Just mount the left intercooler (rubber suspended) and buy hoses, then I can try it.
I also bought an aluminum radiator and threw the old original plastic
Next to do after this is to:
Mount the new bigger oilcooler
Change intake manifold
Change camshafts
Bought Schrick cams
Intake 260░, cam lift 10,9, valve lift at TDC 0,8,
Exhaust 260░, cam lift 10,9, valve lift at TDC 0,9
1992 Audi S4 2.2t
Unread 13-06-16, 01:11 PM   #11
V6quattro
Netherlands
V6quattro's Avatar
Nice! I'm interested to see what the cams do. I'm also running 7a cam now and like to upgrade them in the future.
Unread 13-06-16, 03:31 PM   #12
UrS4boy
Canada
Good work. However, I hope you remember the law of diminishing returns. The SMIC in series with the FMIC will add very little temperature drop but a significant pressure drop (bad).
UrS4boy is offline   Post Tools
Unread 13-06-16, 07:39 PM   #13
Aandreaaz
Sweden
Aandreaaz's Avatar
Yes i'm aware of that but thanks for your reminder, always nice to get comments from people
I'm afraid that it will create some resistant in airflow :/ haven't had any back pressure with the old setup...nervous that this setup will ruin a bit for me!
But if it doesn't work it's no more than change it back
Just wanted the challenge to fabricate it, first time welding aluminum
1992 Audi S4 2.2t
Unread 13-06-16, 09:22 PM   #14
s0_big
Sweden
s0_big's Avatar
Nice What intake manifold are you going to use?
s0_big is offline   Post Tools
Unread 14-06-16, 01:39 PM   #15
Aandreaaz
Sweden
Aandreaaz's Avatar
Just an AAN intake manifold that has been reworked a bit and had the service channels removed
1992 Audi S4 2.2t
ę2003-2016 S2forum.com. All Rights Reserved.
