Hi, just digging for some part numbers as above.
Callipers are missing their anti squeal shims, and brakes are sounding
I,ve used the lube but still giving problems.
I did a search and found some Porsche part numbers for shims, but they come with diameter sizes, and I'm not sure which are the correct ones for front and rear little reds.
Porsche numbers below.
44mm 965-351-096-00
36mm 964-351-096-01
30mm 964-352-096-00
28mm 964-352-096-01
If any of these are correct could you make it clear which numbers correspond to front and rear.
If not does anyone have a clear link to the Porsche and Audi P/N that would be good
Cheers.
rs2315.
44mm 965-351-096-00
36mm 964-351-096-01
30mm 964-352-096-00
28mm 964-352-096-01
Cheers.
rs2315.
