Hi Guys, would like some opinions on front brake upgrade using RS3/TTRS 4 piston brembo calipers rather than the popular 996 calipers.
Reason as follows:
1. Can get a fully reconditioned pair of calipers in red with brembo script for £350, 996 calipers are around the same price on ebay but not reconditioned.
2. RS3 piston sizes are supposed to be 40/44 so larger than 996 calipers and very similar to the original G60 twin caliper (40/45) so pedal feel will be the same.
3. Caliper brackets are available for around £150 shipped to UK from Epytec in Germany.
4. The brackets allow use of the a8 323mm disc (cheap).
5. Pads are available for £35 a set.
Thought its something a bit different to the 996 route and effectively uses an oe Audi caliper and I don't need or want to go to 18in wheels it will fit under my 17s or maybe even 16s in the winter (if not I also have a cheap and cheerful A3/TT 312 caliper adapter, A6 314 disc and 57mm piston A6 calipers, again keeps pedal feel similar to riginal g60).
All in with calipers/discs/adapters/pads the RS3/TTRS conversion comes in at about £625, I could do the 996 route for maybe £600 with non recon calipers.
Not worried about the reputation of TTRS calipers, all the problems were I believe pad related not with the calipers themselves hence the glut of 2nd calipers around a few years ago.
I also believe RS3 calipers are similar to the Aston DB9 calipers, anyone done this conversion before with the DB9 parts ? or with the TTRS upgrade ?.
Note I do not want to go to Zr17 or 18 (sorry Albert) 6 pots and according to 2 wheel folk law radial mount calipers are better than axial mount (can anyone explain).
Opinions please.
Reason as follows:
Opinions please.
