Doing a 3b engine transplant on my wr ur quattro, trying to find info about the pin position on the wr flyweel which I will be using. Is it in the same position as the 3b one? Any links? Thanks.
3B for WR engine swop.
Why are running the wr flywheel and not the 3b one? There is a differance of 2 degrees between the two flywheels that is what i have noticed.i am running a 10vt wr engine on a 3b ecu.The wr is 60 degrees btdc and the 3b ecu requires 62 degrees btdc.
Originally posted by trebormc View PostWhy are running the wr flywheel and not the 3b one? There is a differance of 2 degrees between the two flywheels that is what i have noticed.i am running a 10vt wr engine on a 3b ecu.The wr is 60 degrees btdc and the 3b ecu requires 62 degrees btdc.
I used a ng flywheel and inserted the pin for the trigger at the 62 degrees btdc,and the gearbox input shaft still goes inside the crank shaft bearing.as for hp still working progress.i mite change the ecu to aby one to run with separate coils.
