Тhe car is ex Audi 80 2.6 ABC Avant 150ph quattro 93year,purchased 2013 year then start's the project.Follows: 2.2 20V AAN engine,s2 front and rear bumpers,thresholds and many others.
The beginning:
Wow.. are those stock chassis motor mounts for the V6? The 2.8 have bolt on alloy mounts.. these look like 5/4cyl.
Let me know... I always stayed away from the V6 because of that issue, but if the 2.6 uses the same mounts as I5/I4 then the swap is a lot easier.
www.quattro.ca
B2: 82 Urq into Sport quattro, 82 4000 2-door, 83 80q 2 Door, 83 Ur-q CDN, 85 Ur-q Euro with 3B, 86 4kq, 59,000km
B3/B4: 91 CQ, 93 90q 2.5TDI, 94 80q avant 2.5tdi, 94 S2 Avant
The next step was to chassis.Placing
of mainspring, dampers, switching to 5x112, also drives and devices
We use hubs for the front axle of the rear S4 c4, rear axle whole leg from B5 A4 1.8 tons, ventilated discs S4 + calipersi.Front brake calipersi by bmw E38 with .28 brembo discs 323h30mm,17 -inch alloy wheels Audi A4 S-line
