The Brake Component Weight Thread
  • The Brake Component Weight Thread
    I thought it would be useful to compile a list of different commercially available discs & caliper weights for reference, inc OEM and popular / relevant upgrades.
    If anyone has any of the following items they can weigh please help to compile the list. I have a couple of these at home I can weigh
    Also please add any corrections and/or additional relevant options if you have any
    S2 standard front disc - 276 x 25 [7.0 Kg]
    S2 standard front caliper - [4.2 Kg]
    S2 standard front caliper carrier - [ Kg]
    S2 standard rear disc - 245 x 10 [3.2 Kg]
    S2 standard rear caliper [Kg]
    S2 standard rear caliper carrier - [Kg]
    RS2 front disc - 304 x 32 [8.3 Kg]
    RS2 front disc - 322 x 32 [Kg]
    RS2 front caliper [Kg]
    RS2 rear disc - 290 x 24 [Kg]
    RS2 rear disc - 299 x 24 [Kg]
    RS2 rear caliper - [Kg]
    URS6 HP2 caliper - [6.3 Kg]
    URS4/6 front disc - 314 x 30 [10.8 Kg]
    URs4/6 rear caliper - [Kg]
    URS4/6 rear disc - 269 x 20 [Kg]
    C6 A6 front disc - 347 x 30 [11.1 Kg]
    D2 A8 front disc - 314 x 30 [10.0 Kg]
    D2 S8 front disc - 323 x 30 [10.6 Kg]
    D2 S8 front disc - 345 x 30 [11.8 Kg]
    D3 S8 front disc - 360 x 34 [14.1 Kg]
    996 / Boxster S front caliper [425/426] - [3.5 Kg with pads & clips]
    996 Turbo/GT3 front caliper [429/430] - [Kg]
    996 GT2 6 pot front caliper - [Kg]
    AP Racing 370x36 rotor CP5772-6072/6073 [8.6 Kg]
    AP Racing 355x32 rotor CP3784-160/161 [8.4 Kg] * 62mm pad depth
    AR Racing 6 pot caliper XA6.61.21 / 22 [1.85 Kg]
    RS4/RS6 8 pot caliper - [5.3 Kg]
    B5 RS4 2 piece disc - 360 x 32 [Kg]
    B7 RS4 2 piece disc - 360 x 34 [12.0 Kg]
    B5 RS4 2 piece rear disc - 312 x 22 [Kg]
    B7 RS4 2 piece rear disc - 335 x 22 [Kg]
    B5 RS4 rear caliper carrier - [Kg]
    Cayenne / Toureg 17z caliper - [6.3 Kg with pads & clips]
    Cayenne / Toureg 18z caliper - [6.5 Kg with pads & clips]
    Good post and look forward to how this progresses.
    Just weighed these.
    A new professionally refurbed S2 G60 caliper weighs 9lbs 2oz (4.18kg)
    A new brembo URS6 disc weighs 23lbs 7oz (10.75kg)
      Excellent a great start, thank you
        I use a few catalogues for my info-
        http://bremboaftermarket.com/En/Car_...ue_Search.aspx
        http://apecbraking.co.uk/catalogue/size
        http://www.national-auto.co.uk/asset...-_nov_2014.pdf
          Suggest that, where possible, a link to the Brembo product page is added, as it's a full technical specification!
            andy - porsche are not on apec even though I have a set of the cheapy pads for the gt2 6 pots. the pads are huge and weigh a fair bit. cannot see Ferrari 550 which is same either. again no gt2 on the brembo page
            ill weight them. gt2 6 pot. 993 tt disc and alloy bell.
              Excellent thanks Gaz.
              Andy I agree be good to get a library of Brembo technical drawings from the Brembo site but I am reluctant to link to pages as the link will inevitably die at some point. Will have a look later at downloading them.
                Alex, those S2 caliper carriers can't weight 4kg mate.
                  Correct - copy & paste error
                    My Brembo 6 pots are 1.85kg
                    Ap 370mm x 36mm disc 8.56kg
                    Bells 500g ?
                    Chef
                      I am a flawed individual too...it's called being human.
                        996 / Boxster S front caliper [425/426] 4.08Kg (With new Pads)
                        D2 S8 front disc - 323 x 30 10.9Kg (National Grooved not drilled)
                        Eric
                        95 S2 Avant under rebuild.
                          Great thanks Eric
                          James - do you have part numbers for your calipers & rotor for reference? (Not hat may folk will be choosing them I shouldn't think )
                            A6 & A8 rotor weight.
                            A8 360mm rotor weight.
                            A6 347mm rotor weight
                            HTH, Chris
                            "Nulla tenaci invia est via"
                              Cheers Chris, can you confirm what platform? I will add them to the list
