That's the proper name.thanks!
Mechanic I know has one.
You can hear rust burning off.
No messing with wd40 first, as long as you can position it you can
Reason: Link
I've been thinking of rewinding a microwave transformer to give silly amps but low volts n having a wand with 2 pins that you touch to a nut n heat it right up for a cheaper version.
Oh do tell. Put mains in the secondary and then take low voltage from what would of been the primary? Or complete rewind with heavy copper? An arc welder could do similar with the current wound up? I have a 350amp murex....
