Audi S2 front hubs
  • Audi S2 front hubs
    Are Audi S2 front hubs the same as Audi 80 ones apart from the stud pattern?
    Need a left or right S2 hub to get some caliper brackets made and can't find any S2 ones but Audi 80 ones are on ebay
    as far as iam aware they are the same except the pattern, same offset too, iam sure someone will be along shortly to confirm
    thanks
    mal
      Same as 2.6/2.8 B4.
        Think S2 ones are slightly larger in diameter.
          Yes, 131 against 129, IIRC. But it does not affect anything.
          BTW, hub-carrier with hub together from non-v6 B4 or coupe typ89 with 75mm bearing meets topicstarter's requirements too.
            Thanks for the info guys
              I have a set of 4 stud front hubs converted to 5x112 for sale
              Used for 5 yrs with no issue
              Let me know if you're interested
              Gav
              S2 Cabriolet.........
