Audi S4 small drag project
  • Audi S4 small drag project
    Hi, I have upgraded my car about 2 month ago from a Dacia (renault 12) to an Audi S4 quattro, AAN, engine, and was pleased with it, apart from fuel consumption, but that is another story. I was following the racing scene in my country (RO), for about 4 years, but never been part of it, but i want to change that, so i bought a second Audi S4, crashed, but hopefully this will become a small project, (meaning time and money - small). To make a long story short, i want a drag car, which will only do drag races, so it does not have to be street legal. I want a low 11 sec car, hopefully, and a somewhat good reliability. My thoughts atm, are some like this :
    - small weight - i really dont need anything in my car, which has no use - so i hope about 1250kg
    - Upgraded power to about 400-450 crank hp, + 150-200 NOS shots
    now, this is what i want, but i want to know the following (i read most of the post from project forum, but they are mainly street driving, or andurance, - drag car with high buget, so i am not fitting in) :
    - stock crank - will support this kind of power ? will be betere a tdi crank, which i can find, quite easy?
    - i will change rods (to stronger ones) , and piston (to lower CR), probably from 034 , any better alternative ?
    - headgasket - dont know which one ,
    - stock Head flows quite well from what i understood as i don want to pay 1000$ for a 1000 hp flowing head,
    AAN intake, i dont thing that will take about 400 hp, so probably some made in RO (cheaper), or Wagner
    - high output coils, from 034 (a must ? )
    - Exhaust Manifold, Wagner tubular
    - Downpipe, and exhaust, will be made locally , - 3'' or 4" i dont know, i am waiting for recomandations and maybe a side exhaust, no cats, mufflers, etc.
    - Oil Pump, - stock ?
    - Wastegate - dont know, advice needed
    - VEMS , because i can tune it in RO (and cheaper)
    - FMIC (it will not have front bumper, so it can be quite large), pipes, made here, -core imported
    - injectors , from 034 will be acording to final power, and turbo suggestions.
    - fuel pump, dont know, maybe a small front gas tank ? and 2 fuel pumps ?
    - Turbo - i saw that many drags audi use GT40, or something quite large, i think that is to big, for me, as i dont intend to stroke the the engine, so i am waiting for recomandations again.
    - i gueese that my stock 5 speed, wil not hold that powers, so maybe a diesel quattro gearbox will fit (i know that is has different gear ratio) as i cant get my hands on an rs2 gearbox.
    - clutch , advice neded.
    Bottom line, low 11s, not street legal, small budget, medium reliability
    PS. sorry for my poor english, (i was learing russian in school), and my poor tech skils, but i want to ask, and learn from others mistakes, rather that from my own
    http://www.034motorsport.com/product...roducts_id=498
    vs
    http://www.034motorsport.com/product...roducts_id=612
    ? the same for the main bearings, is better RS2 spec, or hardened ?
      hello
      the old 5tranny in the aan s4 is up for the job of these powers, there have been 600plus engines, running that gearbox. Both in Norway and sweden.
      japanischer industriabfall nein danke!!
      www.rackeltrim.se Icelandic Division
        Hmm, ok, a quick question, what size are the conectors on oil cooler?
          I've been recomanded this turbo Garet GT30 A/R 70, aiming for 450hp, it is a good buy ? i want to paire it with wagner tubular, it is a straight mattch ? or i need some flange adaptation, i want to buy it this week so i am waiting for advice
            AAN inlet manifold will easily do 400hp.
              Hope so, i was asking if gt30+wagner tubular (http://www.wagner-tuning.de/produkte/abgasrs2rohr.php) is a good match
                Im in process of oredering some parts, and i want to buy this injectors RC Engineering
                RC Engineering
                Flow Rate - CC's:
                650 CC's / MIN @ 43.5 PSI
                Flow Rate - LB's:
                62 LBS / HR @ 43.5 PSI
                Resistance:
                12.5 Ohms @ 68 F
                Voltage:
                8-15 Volts, nominal 13.5 Volts
                Amperage:
                1.0 Amps
                Pressure:
                Min 30 PSIG / Max 100 PSIG
                Have anyone used them, ? are this ok ? thanks
                  First parts arrived today, thanks Aron. Weight 565grams
                  Monday will come intercooler and oil cooler, and i am waiting for advices regarding the other parrts
                    Update, size matters
                      Next on order, good stuff or not ?
                      Fuel Pump, Aeromotive A1000 High Flow Pump / 600 lbs/hr of fue
                      96lb EFI Injector, Low Impedance
                      Fuel Pressure Regulator, Aeromotive
                      ARP Main Stud Kit, Audi I5
                      ARP Head Studs, Audi I5 20-valve
                      Rod Bearing Set, Coated, Audi I5 20v
                      Main Bearing Set, Coated, Audi I5 20v
                        nice
                        good project there, and the original aan manifold will do 600+hp when service chanels are taken away.
                          Service channels ? hmm gotta find out, about that
                          The car will be completly stripped down, and remove almost everthing what is not nedded, i am giving second thoust to power steerin , it is a quite heavy front end
                            the
                            service channels are the little holes where you can, stick your tool and remove the bolts on the Im down by the head.
                              Packaged arrived, 034motorsport nice services
