2 x Audi RS2 for the price of one hehe
  • 2 x Audi RS2 for the price of one hehe
    Two Audi RS2 for sale. Both with papers.
    First one:
    Early RS2 model.
    Vin waczzz8czrz000101
    Engine number ADU 0000008
    I bought the car from somebody who bought it in Spain in 2004 and kept it there until 2009.
    In 2009 he registed the car in Romania.
    In 2010 he unregistered the car to avoid paying taxes.
    I bought it last year in autumn.
    It has 114.000 km mileage showing in the clocks.
    The car has suffered an accident in Spain and TUV Spain changed the vin from
    waczzz8czrz000101 to M0108032
    I've checked with TUV Romania before buying the car, they said it matches to AUDI RS2 QUATTRO.
    Rocco said TUV Spain said the same thing.
    First I bought the car to break it but then I was convinved by people here to restore it.
    I thought to also buy a new shell with no damage to move everything to the new shell, thus making a perfect RS2. That is why I have bought the other shell that's included with this sale.
    Second RS2:
    The second shell is LHD and it has UK papers. The seller of the second shell must send me the doors and front wings, they are yours after he sends them.
    It's your call, either you move everything to the new shell or keep it like this, the car still runs like a rocket.
    I can make any kind of video test you want.
    I have pictures of the engine rebuild.
    I can send you copies of the papers of both cars.
    Ask me and I will help you.
    Price for everything above is 18.000 EURO. Just a friendly reminder, if you drop 3000 euro from the price (that is how much I paid for the 2nd shell delivered home), and 7000 euro in parts and labor for everything I did to the car, you get a price of 8000 euro for the car.
    https://drive.google.com/file/d/1Kvd...eIrXZRp4A/view
    This video is from Woerthersee 2015
    Now boring technical stuff:
    Exterior and chassis
    The front bumper has a little crack on the right side.
    New headlights
    New trunk door opening mechanism
    New rear light panel ( the one where the number plates come on standard b4 avant) - not installed
    New Rs2 rear badge (not installed)
    New left front door lower trim (not installed)
    wheels and tires
    18" Porsche Turbo wheels, are not bent, I've checked them at the tire shop, they are 100% straight. The tires have little usage.
    New Porsche caps for the wheels bought from Porsche Classic Online Shop.
    17" original RS2 wheels with winter tires.
    gearbox
    Currently installed:
    Modified 01e tdi gearbox for longer 6th drive. At 3000 RPM --- 150 km/h
    This gearbox can be purchased extra for 350 euro.
    Otherwise the car will come with standard RS2 gearbox.
    Stock clutch in perfect condition.
    Interior
    In good condition, with carbon, grey alcantara.
    Steering wheel is not from RS2, it's from S4 or S6 I believe.
    engine
    4000 km usage since rebuild.
    1000 km running-in period after rebuild.
    2500 km used for going to Woerthersee
    Engine Rebuild:
    Block usage measured: 0.01 so no need for rebore
    Honing: Perfect
    Pistons Condition: Perfect
    Gaskets replaced:
    sump gasket
    oil pump gasket
    crank rear seal cover gasket
    oil filter mounting gasket
    exhaust manifold gasket
    intake manifold gasket
    turbo gasket to manifold
    turbo gasket to downpipe
    camcover gasket set
    cylinder head gasket
    water manifold gasket
    O-rings replaced:
    oilpump suction pipe oring
    oilfilter housing bolt orings
    water manifold orings
    water pump oring
    thermostat oring
    rear water plug on block to heater matrix oring
    Seals replaced:
    Valve seals
    crankshaft front and rear seals
    camshaft seal
    Other parts replaced:
    intake valves
    exhaust valves
    thermostat
    cover for thermostat
    pcv valve and T parts and small hoses
    colant plug on block to heater matrix
    valve guides
    main bearings,conrod bearings SPUTTER
    water pump and timing belt kit
    cylinder head bolt set
    sparkplugs
    Upgrades:
    Cartec Wagner Exhaust manifold - new, bought from Jonas's first group buy
    tfsi coils conversion kit - new from Norbitron
    red tfsi coils - new
    another motronic ecu with soft for 380 hp, launch control and flat shfit (not yet received from PRJ)
    exhaust
    new 70 mm stainless steel exhaust with 2 Magnaflow exhaust boxes
    2mm thick pipe
    original exhaust with cats is included also
    brakes and suspension
    Big Reds.
    The car brakes perfect, the steering wheel doesn't shake when braking.
    The discs and pads still have many life left.
    H&R coil over suspension.
    Hi, could you tell me the specifications of the Porsche Turbo wheels, namely the ET and centre bore? I've been on the lookout for a new set of wheels for my RS2 but can never find wheels with the right size and fitment specifications!
    RS2 - Project Mental Wheels
    RS2 - LHD on the road again
    RS2 - reduced to component parts
    RS2 Saloon replica
    A4 1.8T
    BMW 320d Touring M Sport Business Edition auto
      Hi, i bought the car with those wheels, i think they are et52 with 8j. Center bore is the same with rs2 as they are straight fit.
        Thanks, it is the centre bore I am having trouble with the most, some say it is 73.1, others say it is something else so it is very confusing. Thank you anyway
        RS2 Saloon replica
        A4 1.8T
          No problem, well maybe another member can tell us the center bore of rs2
            I'd love to have your cars for the interior and wheels alone, but I think I have enough RS2's for now!
            RS2 Saloon replica
            A4 1.8T
              Sorry for the off topic reply
              " Another problem for RS2 owners is that Porsche wheels more commonly have a centre bore diameter of ~71mm, which needs to be enlarged (73.1mm) for the RS2 application."
              http://s2central.net/wheels_tyres.html
              https://www.youtube.com/watch?v=TBmv4YW1kmA
              Eric
              95 S2 Avant under rebuild.
                Yes, 71.6 I think, it's and absolute nightmare. Though when I was at VRS yesterday, they had a delivery of a set of 19" wheels and on the box label it said PCD 112x5; ET32; and c/b 73.1! They were from 3SDM.co.uk or something, so I may check that out....
                RS2 Saloon replica
                A4 1.8T
                  Up!
                    Good luck with the sale
                      I have been offered 13.000 euro only for the silver rs2 if everything in my ad is true.
                      I would like to mention that everything in my ad is true and at this point I am willing to give the silver rs2 for 13500 euro with the tdi gearbox installed on the car and the original one (with original gearbox mounts) in the trunk.
                      This offer won't last long.
                      The extra ECU has arrived from PRJ but it's not yet installed.
                      The car is registered on my name and it can be driven away anywhere in Europe but I have to get some assurance that the Buyer will send me the number plates back.
