Coupe Quattro 2.7 Bi-Turbo
  • Coupe Quattro 2.7 Bi-Turbo
    My Coupe 2.6 ABC => 2.2T AAN = 2.7T swap
    K04 RS4 Turbo
    RS4 Cluch
    RS2 6sp Gearbox
    Passat B5 TDI Shifter
    S4 B5 Instrument Cluster
    Denso 280lph fuel pump
    76mm Exaust
    2.7T AZA Engine (Japan 79K km)
    Motronic 7.1
    VAG service Almaty
    master-service.kz
    really nice work!!! We need some movies!
      Do you have any pictures how you sorted out a8 vacum booster system on the car?
      Other than that, good job!
      1990 2.2 20VT Audi Coupe Quattro
      *Hx35/k26, MaxxECU, Wagner EM/IC *RS2 Recaro *4pot-Brembo *3" turboback *Treser *Koni/H&R
      1990 Audi 200 20v Avant 2.2 20VT *7 Seater *Full electric gizmos
        i like that a lot!
        Although i personally would have went for a big single turbo mounted at the rear like a 2.5/3.0TDi
        Sean.
        1993 URS4 Avant Emerald Green 350+bhp
          Wow
          More info/pictures needed
            Thank you. Video coming soon
            My friend did the vacuum system A8 as follows:
            https://www.drive2.ru/l/1926177/
            Originally posted by Sleeper_Avant View Post
            i like that a lot!
            Sean.
            Two turbines have early spool with 1500rpm . For a city that is very convenient
            Originally posted by andy10v View Post
            Wow
            ok
            Sorry for my english)
            VAG service Almaty
            master-service.kz
              Some video
              VAG service Almaty
              master-service.kz
                Front bumper of England
                Price 120$
                Motor of Japan А6 С5
                VAG service Almaty
                master-service.kz
                  Cluch from AS400 B6 2.7T ABT
                  VAG service Almaty
                  master-service.kz
                    the movies are not working
                    TWINCHARGED power,zero lag
                    AEM W/M injection
                      Ive fixed the movies for you.
                      What was the reason for fitting the passat shifter? Is it a straight swap?
                        Nice work.
                        Sounds weird listening to a B5 V6 exhaust note on a B4 Coupe.
                          thank you
                          Together with gearbox 01E replaced shifter.
                          Old gearbox was type 01A. Gearbox blown to 380 hp
                          Passat B5 TDI (01E gearbox) shifter similar to S4 B5
                          Shifter Linkage shortened by 37mm
                          VAG service Almaty
                          master-service.kz
                            Very nice build!
                            Audi S2 Avant - 600whp
                              Looks great, what size are the down pipes?
