I have a ABY cylinder head on minimum skim limit of 118.1 mm from face to top of bolt hole on cylinder head and just wondered if......
1) using a standard mls aby gasket would keep comp ratios ok, or should i opt for a thicker gasket.
2) is 034 motorsport in the US the only option for a thicker gasket? They offer 2 that lower comp ratio by 0.5 or by 1.0
Brian
Brian
