Piston size on 429/430 Porsche 4 pots
  • Piston size on 429/430 Porsche 4 pots
    Anyone know the piston sizes on the 996 Big Reds as fitted to the C4S & GT3
    Hi Alex,
    996-351-429 & 996-351-430 GT2/GT3 C4 Turbo Front Calipers...
    Piston Sizes 38 & 44mm
    BLOG: http://quattro10vt.wordpress.com/
      Big reds?
      The Mitsubishi Evo V,VI,VII,VIII,IX brembos 4 pot calipers has 2x 42mm and 2x 46mm pistons.
      Works originally with 320x32 rotors and are far cheaper to buy second hand than the overpriced gt3 4pot big reds.
        Tomas, what are you still doing here? Go away ricer!
          Thanks for the info guys
          I did look at the Evo calipers but I'm not sure they can swallow as large a rotor?
            Still got 2 Audis , 2x engines, and hundred parts stored
              How large?
                Around 350mm?
                Also what size rotor annulus do they use? (The width of the contact patch on the rotor?)
                TBH I never see them go for much less than £300, which you can pick up GT3 calipers for too
                  Around 350mm?
                  I can ask in the MLR forum about disc thick and diameter options
                  But what everyone does is fitting very good quality 2 piece rotors from Performance Friction , good fluid , braided lines and very good pads for your requirements ( pagid , carbotech, PF ... ) and that's more than enough .
                  Or they goes to the 6 pot conversion with AP or Alcons... +2k£ ..
                  About calipers, I've seen bargains in the private part for sale forum...
                    Thanks Thomas. Yes this is my plan, floating two piece setup
                    I will get on MLR to have a look
                      iirc evo discs have issues.
                      got gt2 6 pot for the little extra cost. saves doing it again
                        Yeah the GT2 6 pots are very nice and light, but they cost a fortune second hand and pads are also extortionate.
                          With such brake disc diameter why not to go Porsche Cayenne 6 pots? At ours they are often cheaper than RS2/EVO/Boxter/996 when second-hand.
                          S8 D2 345mm brembos would be my favorite option because of radial bracketing and second hand price much lower than porsches' brembos.
                            Alex you are better off going Porsche Cayenne 6 pots as they are more readily available. However I had the GT3 4 pots on my S2 and they are effin fantastic brakes!
