aftermarket handbrake calipers
  • aftermarket handbrake calipers
    Evening ppl.
    a few of you that have seen my avant know that i run a lambo 8pot front caliper.
    Well after a long search i have the 4 pot rears.
    I am going to have to run a aftermarket hand brake caliper. (like found on a aston Martin)
    Any one ever done a conversion like this on the rear???
    Lance
    Boost is what makes the world go round.......!
    theres definately a thread in here somewhere where someone has had a mount made up for an avant , check the brake threads
    NOT a car dealer! just an S2/RS2 enthusiast
      Compbrake make hydraulic ones
        John B used the Lambo/Aston handbrake caliper on his coupe, using the longer avant handbrake cable
          Thats the thread i was thinking of
            Any one got a link to it please?
              http://www.s2forum.com/forum/showpos...19&postcount=4
              Maybe?
              Eric
              95 S2 Avant under rebuild.
                http://www.s2forum.com/photoplog/index.php?n=2884
                  Sweet. that is what i wanna do.
                  grad it has been done so i know it is possible.
                  Cheers for the help people.
                  lance
                    I also have one pair of brackets left in stock for the handbrake caliper
                      for what kind of caliper mate?
                        Bambridge how much we looking at???
                        If you could pm me.
                        Lance
                          I'm going to fit rear Cayenne Calipers w/350mm rotor on the rear axle plus Brembo E-brake Calipers.Same as the photos above.
                          one of a few I5 from Asia.
                            On the rear, I have used 4 pot Cayman S callipers and mechanical cable operated callipers to comply with MOT.
                            If I could load photos here I would!
                            Pembo
                            quattro - Original 4WD rallying
                            Rally Car photos
                              If you don't mind me asking pembo what hand brake calipers did you use?
                              Lance
