Thanks guys!
@Rusty I am already looking for some mint 19" LM's
I will not drop it because the ride is perfect for our rods.
Also now is on 18". On 19" it will look nicer, the space between the arches and the rubber will drop.
I will also add the brakes below, for more beauty than stopping power, and gotta talk with PRJ about 300 hp
Just had my first service, changed the oil and filters, at 18.000 km
The consumption has dropped a lot since buying the car.
So far I like the car a lot.
I noticed in the service shop that my front tires are almost slicks
Since I drove 5000 km with winter tires, that means that I have finished the front tires in only 13.000 km
I told them that they should give me new tires, after all it's under warranty.
They said that they will give me a new right foot, a lighter one
In my country (and I'm sure not only in my country) most of the people from rural areas use that to extract alcohol from fruits that have gone through the process of fermentation.
You simply add fermented fruits + water in the "cazan" and then make a fire under it.
Vapors of alcohol and water will start to build which will travel from the cazan through a pipe to a boiler where they cool down and convert into liquid.
First the most high % alcohol will come, and with time the % will drop. So it's up to you when to stop and thus deciding the % of the end result.
The resulting alcohol is in fact a liquor called TUICA, PALINCA, or RACHIU.
I'm sure that I've heard about RACHIU in other parts of Europe as well.
So if you don't want to pay high prices for hard liquors you should get one.
In my country gypsies fabricate these things.
