D2 A8 with 2.7t/01e swap questions
  • D2 A8 with 2.7t/01e swap questions
    hi, I have a 2000 A8q with 40v and autotrans. im looking to swap this all out for a 2.7t APB motor and 6speed DQT 01E transmission.
    a few questions.
    will the engine mount arms from a euro d2 a8 with v6 APR,AQD,AMX bolt onto a 2.7t block?
    APR,AQD,AMX are 30v correct? did these motors come in Quattro cars or just fwd? > longitudinal fwd? Quattro vs fwd, how different could the bellhousing positions be?
    how much wider are d2 frame rails vs b5/c5?
    any other tips/links/suggestions much appreciated, thanks
    BEAST '90 CQ 24v VRT / O1E / v8 rear, HOLSET SUPER 40 http://www.theprojectpad.com/viewtop...1&t=193#p37887
    DD '86 4kq BLAZE, swapping aba/16vT and O1E http://www.theprojectpad.com/viewtop...1&t=201#p38264
    to do this ( big ) job, you need the hole donorcar.. the wiring, the ECU unit, the pedalbox the propshafts, the spring and dampher in front end... and may its q car you need to check out the rear ends ratioi( the may diff from autobox to manuell...)+++
      after tons of research, its a go!!!
      big post to come this weekend
        Look forward to seeing the results
          major update post / progress this weekend
          keep an eye out
          yup, that's right , im making a big comfy couch b5 s4 hahah
            Nice stuff, just registered here to watch this
            I was contemplating something similar for my 01 S8 manual
              Interesting!
                Slightly unrelated but I saw an old D2-S8 at the weekend and they still look really tasty. In Europe they had 01E manual and a V6 non turbo engine was fitted too - so mechanically it shouldn't be impossible to get the 2.7T installed with 6-speed box as its the normal in-line setup for quattro AFAIK.
                As stated already though - the 'fun' here will be all the coding & dependencies for the donor ECU with IMMO/Cluster & such so it runs... should be a good project !
                  Where's the promised update?
                  This is going to be such an awesome project, don't keep the masses waiting! haha
                  Find me on Instagram @pry4sno
                  2010 Golf Sportwagen TDI /// #farmenwagen
                  2002 Dodge Ram 2500 24v Cummins 4x4
                  1992 80q 20v /// Eventual AAN'd Winter Sled
                  1990 Cq /// Project: Because Racecar
                    hahaha im working on it, waiting for a few more answers, so its actually the start of a project thread vs a post of a million questions
                    oh itll get done don't worry, ive done more complicated builds
                    we just get to play more ecu games this time
                      ok, good news, I seem to have the immo worked out so everything plays nice together
                      and I got a lead on some rs6 intercoolers that should fit reasonably with all the new found room in the engine bay.
                      now I can get a thread started w/o nearly as many questions and confusion.
                        PROJECT THREAD
                        started and updated
                        http://www.s2forum.com/forum/showthread.php?t=73854
