KW V3 Avant - rear rebound adjustment
  • KW V3 Avant - rear rebound adjustment
    Interested to know anyone's rear adjustment settings and if anyone has made modifications to allow adjustment on the car? It looks to me like you'd have to cut a notch in the strut at the height of the shock retaining bolt to access it, wondering if anyone has done this?
    Currently thinking of just setting it at 10 and then balance the rest around it. It's what Sonic's coupe is set to on the rear after lots of fine tuning so seems like the best start.
    I did cut a notch in the strut. Works perfect.
      Thanks. I should have got a new blade for my angle grinder today! Just been building up the struts for the rear, I'm gonna take the struts back off, measure them up and do this now to make sure I can get the most out of my investment in V3's.
      Any pics? I'm guessing a 2-3mm wide slot about 3cm long in the right location is what it needs.
        2 to 3 mm is good but make the cut as longs as posible so you can make the full swing from klick to klick. I can take a photo this evening if i don't forget.
          This one
