My 1.8t CQ - 2 engines later....
  • My 1.8t CQ - 2 engines later....
    Well I picked up my buddies '91 CQ as he was moving out of state. He swapped tan interior for a platinum one and started to build an s2 clone. After spending months on a no start issue...he sold off lots of parts....then I bought it while picking up a transmission for my v8 cq.
    while waiting on a few missing intake and fueling pieces i whipped out one of these.
    then i realized what the true no start issue was...
    http://distilleryvesper8-8.ak.instag...1f970a_101.mp4
    so off came the head...
    snagged a b4 front/hood, a 7a, and a bag-o-snakes
    v-banded
    034 engine mounts
    034 front snub mount
    034 silicone coolant hoses
    034 silicone breather hoses
    new reman starter
    new reman alternator
    new reman crank dampener
    new crank "super torque" timing gear
    new timing belt, water pump, roller
    ran but sounded like it was missing badly...so Javad@034 hooked me up on a new injector set
    decided to test compression on the replacement 7a since it still barely ran.... 0, 0, 0, 148, 148
    about 2 weeks ago i toyed with the 1.8t idea and grabbed our mock up 1.8t aeb block/awm head...
    here is what i came up with so far with parts laying around
    last weekend i built 2 motor mounts and here is where i am today.
    so much room upfront its fantastic.
    what i have already:
    14lb solid flywheel
    stage 2 sprung 228mm clutch
    aeb engine harness converted to newer 4 wire coil packs
    '91 Pearl 3.6 V8 CQ - building
    '13.5 Jetta GLI - toy
    '15 Subaru Imprezzzza - work daily
    hausofdub.com
    You gonna finish this one?
    Sent from my HTC One X+ using Tapatalk
    1994 URS4 Avant RS2+
      hausofdub.com
        i know i know still not done...
        ordered new rod bearings and few other things so i can button up the block
        scanned this is in last night and it is true to scale
        hausofdub.com
          little update. waiting on new oem valves from Issam@INA to finish up the head.
          new oem main bolts
          new arp rod bolts
          new rings
          new rod bearings
          new oem crank bolt
          new full victor reinz upper and lower gasket kit
          new oem head bolts
          new 15lb chromoly flywheel single mass
          new sprung stage 1 clutch 300ft/lbs
          New Conti timing belt kit
          New metal water pump
          have 3 ecu's. tinkering with a custom flash.
          found a radiator solution
          just need valve to finish the head.
          started to modify the power steering system back to a vac assit
          picked up a 2004 A4 k03s. little bit of a scrubbing and paint...
          also going to swap on a obd2 vr6 12v throttle body...so i needed an adpater. offset to clear the alternator
          hausofdub.com
            are you planning on using the stock 1.8t Wiring harness? have you integrated it into the stock setup yet? if not, do you mind documenting it well?
              yes, using a 058 B5 A4 harness that has been converted to 4 wire coilpacks.
              I plan on pulling the dash to make this as oem as possible. I will document all changes.
              hausofdub.com
                awesome, i'm doing a similiar setup in a b4 90 stateside.
                  Sorry Ruffiano, been working on the swap at a causal pace.
                  ended up picking up 2 AEB heads
                  had to modify the pilot bearing since i started with an automatic crank from a B5
                  radiator is in. need to weld a bung in for the fan switch. modded the radiator cap to pass coolant through and seal.
                  picked up a MK3 1.9 TDI water pump pulley and a MK2 1.8 thermostat outlet flange. this weeks task is to finish the cooling system.
                  hausofdub.com
                    needed to tie in a few coolant lines so i picked these up. looks like these are made for sensors...these have a 3/8 fitting so i can put a 90* and a 5/8 barb fittings on.
                    the lower union ties the coolant bottle in
                    also snagged a new 2300 cfm Perma-cool fan. it is nice having Summit Racing 20min away
                    hausofdub.com
                      hausofdub.com
                        Good job.
                        This space is crying out for a massive FMIC:
                          Oceans of room!
                          Very tempting...
                          Find me on Instagram @pry4sno
                          2010 Golf Sportwagen TDI /// #farmenwagen
                          2002 Dodge Ram 2500 24v Cummins 4x4
                          1992 80q 20v /// Eventual AAN'd Winter Sled
                          1990 Cq /// Project: Because Racecar
                            IC brackets are temporary. Talk about a reduction in heat soak with all that space!
                            hausofdub.com
                              swapped my front coils from the v8...the rear will be next
                              hausofdub.com
