S2 avant 800hp+ project
  • S2 avant 800hp+ project
    BREAKING audi s2 avant 800hp+ unfinished project.
    spec as follows:
    body:
    1993 audi s2 avant in titan grey
    fiberglass rs2 front grille
    homemade honeycomb lower grilles
    bottom of bumpers sanded and painted ready for vinyl wrap
    90 b3 rear panel
    rs2 rear spoiler with brake light
    rear de-wiper
    everything underneath and in arches has been cleaned and painted with underseal
    front wings (in primer)have vents welded in (rh for intake, lh for pas liquid cooler)
    front bumper valance
    homemade rear aero kit - diffusor
    spare wheel well delete
    interior:
    original apart from spare wheel well delete...
    chassis:
    everything has been sand blasted and painted
    solid subframe bushes
    powerflex bushes everywhere else
    solid rear tie rod bushes
    solid front tie rod bushes
    solid front top mounts
    apikol billet rear diff mount and bushes
    derlin/billet alloy engine and gearbox mounts
    rs2 farb
    034 motorsport 25.4mm rarb with neuspeed brackets
    FK konisport coilovers
    new track rod ends
    new ball joints
    cast front wishbones
    cast rear upper wishbones
    new arb links front and rear
    density line front engine mount with billet bracket
    drivetrain:
    rebuilt s2 rear diff
    rebuilt rs2 gearbox with carbon synchros
    all new cv joints
    standart drive shafts cleaned and painted
    cleaned and painted prop shaft with a new support bearing
    gearbox, diff and all mounts have been cleaned/blasted and painted
    standart steering rack, but electric pas pump fitted and plumbed, just requires wiring
    rs6+ front 8pots + 365mm discs front
    911 4pots + 330mm discs rear
    hydraulic handbrake
    034 motorsport/jhm solid short shift
    034 motorsport uprated linkage
    braided clutch line
    all new brake lines
    all new homemade braided flexi hoses
    all new bleed nipples
    new metallic throw out bearing
    converted to vacuum brake servo
    abs delete
    wheel studs instead of bolts + 15mm hubcentric billet spacers
    currently on a8 sport 18'' alloys
    engine:
    aby block bored to 82.5mm
    wossner pistons 8.0 cr
    h beam rods
    all new bearings
    7a crank knife edged and put on a diet
    034 motorsport single mass alloy flywheel with changable face
    60-1 trigger wheel on the back of the crank
    arp main studs
    arp head studs
    rebuilt oil pump
    baffled sump with breather and sensor fittings and an-12 oil return fitting
    billet core plug
    billet breather adapter
    oil distributor has an-10 and an-4 fittings welded on
    modified dip stick
    aan front pulley
    new oil return check valve
    an early wagner inlet manifold with 80mm throttle body,
    billet fuel rail and billet injector seats instead of the brittle plastic ones,
    at the back an an-8 fitting for vacuum servo and 3x an-4 for vacuum lines
    3x billet an-8 ''p'' clips for throttle cable
    wagner stainless tubular exhaust manifold
    tial 60mm wastegate
    precision 6766 turbo with a speed sensor fitted by owen developments
    034 motorsport alloy radiator with all original fittings
    aeromotive 1000 fpr
    bosch 3 electrode copper spark plugs
    race spec ported and polished aan head
    0.5mm oversize valves
    hd valve springs
    titanium retainers
    lightweight lifters
    new guides and seals
    schrick camshafts 10.9mm lift 260' duration
    adjustable cam sprocket
    modified valve cover with breather fittings
    ...115 ign coils
    034 motorsport billet rear coolant return flange at the back of the block
    2x 044 fuel pumps with custom pipework
    custom suction system from inside the original fuel tank
    2x billet fuel filters
    an-6 braided fuel hose
    fuel cooler/radiator
    oil cooler/radiator
    i was planning to run it with a motec m800 management + nitrous + Q16 fuel
    in order to finish the car it requires:
    ecu
    wiring loom
    dash - logger
    exhaust
    intercooler and pipework
    paint/vinyl
    nitrous system
    fuel injectors
    head gasket
    adjustable cam gear
    there's probably a few things i've missed but that is roughly it..
    i've also got loads of other parts that can be purchased as a part of the deal so pm me if you're interested or if you need something,
    having said that i'll start a new thread soon with all the parts i've got going too
    '93 S2 Avant breaking
    '95 S6 Avant sold
    '83 80 Quattro SWB
    '85 90 Quattro
    '85 200 Quattro 10V sold
    Pretty rare an S2 in titan grey, bet it looks good.
    GLWS
    Btw. what does a SWB 80 quattro look like that you name in your signature?
      '95 S6 Avant sold
      '83 80 Quattro SWB
      '85 90 Quattro
        GLWS
        it's basically a 2 door saloon/sedan...
        '95 S6 Avant sold
        '83 80 Quattro SWB
        '85 90 Quattro
          Can we have a sale price please
            Is 22k£
              Sorry I read it as that was what had been spent already
                No I've spent quite a lot more than that but I just need to get some of my money back...
                '95 S6 Avant sold
                '83 80 Quattro SWB
                '85 90 Quattro
                  Ignore me then - GLWS
                    Sorry for the off topic however what make is the replica rs2 grille and what is the quality / fit like?
                    I believe you bought the blue 90 quattro with tsr engine from me a few years ago ?
                    Gav
                    S2 Cabriolet.........
                      I thought so, rare cars but with the same wheelbase as other type 85 cars I believe.
                        '95 S6 Avant sold
                        '83 80 Quattro SWB
                        '85 90 Quattro
                          '95 S6 Avant sold
                          '83 80 Quattro SWB
                          '85 90 Quattro
                            '95 S6 Avant sold
                            '83 80 Quattro SWB
                            '85 90 Quattro
                              '95 S6 Avant sold
                              '83 80 Quattro SWB
                              '85 90 Quattro
