coupe rear outer cv joint pn check
  • coupe rear outer cv joint pn check
    Hi,
    Can anyone confirm the following number as a 3b rear outer cv joint and boot
    893407305(h)
    Not sure if it has been superceded or there are newer numbers to quote
    David
    updated so it can be searched, the correct number for the ABY/3B coupe rear cv joint is 893498099PX
    Changed the nearside this afternoon and the difference is remarkable, safe to say the 1992 lobro OEM unit was f**ked. I shall be doing the other side and the fronts soon and also the propshaft and inner CVs
    The part number for the boot kit only is 893498203F for reference.
      Comes with the ABS ring too? Might consider doing these as the next job..CV boots as well?
      1996 S2 ABY Silver
        yep abs ring was integral to the joint, boot, grease, driveshaft bolt and the circlip and rear washer etc.
          What was wrong with the old joint? Clicking noise?
          1996 S2 ABY Silver
            everything grinding on turning to the right and loading it. In the hand, there was significant rotational play in the direction of the wheels turning and the wheel bearing was toast too. Been delayed in changing due to winter and time.
