So just bought myself a 1995 Audi S2 Avant.
Plan is to go 450 HP on RS2 Turbo from IrozMOtorsport with W/M injection and keep a nice sleeper look.
450 HP Plan:
Engine rebuild - Done
Water injection:
Upgrade plan for the rest of the car:
Interior:
Wheels:
Exterior:
Suspension:
Brakes:
Clutch:
Niggles that need to be sorted:
Some pictures from the add:
450 HP Plan:
- 3" downpipe with flex and no coupler from EFIExpress - Done
- 3" Cat back exhaust from Jetex - Done
- 3" cat section with free flow fake cat from Frozenboost - Done
- RS2 Turbo with a billet wheel from IrozMotorsport - Done
- Wagner Evo Intercooler - Done
- Wagner Evo EM - Done
- RS2 Airbox - Done
- 630CC Siemens Injectors from EFIExpress - Done
- Roosemotorsport hoses - Done
- TFSI Coils - Done
- Coil harness - Done
- Fuel pump DW300 with 034MS drop in adaptor - Done
- Fuel pump relay harness from EFIExpress - Done
- Catch Tank from K24R - Done - Minor tweaks to give me a better routing of the hose venting fumes.
- Vems - Done
- Mapping - Ongoing
- Wössner oversize pistons 81,5mm
- Main bearings KS 77209602 STD from cs-parts.de
- Rods sputter bearings KS 77244600 from cs-parts.de
- Thrus washer GLYCO A124/4 from cs-parts.de
- Top bolts REINZ 14-32049-01 from CS-parts.de
- Bottom Reinz kit 08-29178-01
- Integrated Engineering rods
- Head gasket set Reinz 02-29335-01
- 7A Head
Water injection:
- W/M injection Aquamist HFS3 - Acquired
- S2 Extra washer fluid bottle for W/M 893955453C - Fitted
- AEM high pressure pump with custom bracket (mounted in front wing) - Acquired
- Injectors to be mounted in the intercooler - Acquired
- Hoses for w/m. - Acquired
- Small hydraulic tank 893422371A to make place for washer fluid bottle- Done
Interior:
- RS2 Speedometer - Done
- RS2 Aux Gauges - Done
- Cabriolet leather handbrake
- VEMS Round gauge only - To show relevant data - Done
- Centre vent for gauge - Done
- S-Line steering wheel - Done
Wheels:
- Audi S6 C5 Speedline 17x8" ET35 - Done
Exterior:
- Front and rear bumper should be painted all black in vulcan black
- Audi 80 Competition front spoiler lip - Acquired
- Treser black lights - Done
- Treser middle section from Audi 90 - Aquired
Suspension:
- KW V1 coilovers???
- H&R 29909-1 30/30lowering kit - Done
- Bilstein B6 front dampers #34-030868 - Done
- Bilstein B6 rear dampers #24-062121 - Done
- RS2 upper strut bearings - Done
- Front Snub Mount AK-motorsport - Done
- Engine mounts from AK-motorsport - Done
- Gearbox mounts from AK-motorsport - Aquired
- All bushes needs to be changed
Brakes:
- 996 Calipers - Done
- Zimmermann 323x30 - Done
- Porsche Textar Pads - Done
Clutch:
- Sachs sinter metal clutch - Done
- Clutch release bearing - Done
- Proper Radio or 2din conversion kit - TBD
- Upgrade speakers in read doors and front
- Amplifier - TBD
- Install a proper roof antenna
- New timing belt etc - Done
- ISV needs to be change - Done
- Refurbish for rear calipers + new pads and dics - Done
- New bomb from Febi #26538 - Done
- MAF Sensor + Change pins in MAF plug - Done
- Zeitronix map sensor not working, need to check boost hoses - Done
- N75 needs to be change - Done
- DV needs to be changed - Done
- New banjobolt and seals for tanklid and new tanklid + gasket. - Done
- Need to cutout in rear shocks so the spring support sits correctly. - Done
- Fix some minor rust - Done
- Fix light in speedometer - Done
- Fuel filter needs changing - Done
- Oil leaking from turbo return hose, sump plug and from the bracket for the non-ac oil return hose - Done - But it is still leaking from somewhere.
- Small coolant leak from temp switch in water rail - Done was the bloody water hose that was leaking due to a bad hose clip.
