UrS4 6 speed poly gearbox mounts?
  • UrS4 6 speed poly gearbox mounts?
    Does anyone offer poly gearbox mounts for 6 speed box in UrS4?
    And can anyone confirm correct part number for gearbox mounts as vagcat shows about 5 options?
    1. 4A0 399 151 C
    2. 4A0 399 151 B
    3. 4A0 399 151 E
    4. 4A0 399 151 D
    5. 4A0 399 151 L
    '93 Audi UrS4 Avant LPG
    Not sure if Albert does them search for AK motorsport
    sent from my not so smart phone
    ABY Cricket Green Pearl Coupe, blk leather
    THE ONLY TROUBLE WITH DOING NOTHING IS KNOWING WHEN YOUR FINISHED!!!
      He doesn't unfortunately. It is in his plans for the future, but subframe is coming off and I'd like to change 200k old mounts. I would be ok with normal OEM style ones but there are many PN and I assume stiffness changes.
        Not sure if this will work, but sometimes diesel engine and gearbox mounts are stiffer than petrol ones, so maybe consider the idea of oem diesel engine and gearbox mounts where assuming you want to retain the comfort of oem with a small amount of extra stiffness.
        Others will be able give us the benefit of what they know.
          Yep I am using diesel parts. Seem the same.
          Sent from my LG-H955 using Tapatalk
            So this should fit no problem? http://www.ebay.co.uk/itm/FEBI-19802...oAAOSw6n5Xtjjn
              You can fill the voids with something to make them stiffer
                What would slthat something be?
                  Sikaflex would likely do the job.
                    Yes, just like that.
