S2Forum - The Audi S2 Community
Go Back   S2Forum - The Audi S2 Community > Member's Area > Projects
Reply
Thread Tools Display Modes
Unread 03-05-17, 03:01 PM   #76
geryS2
Home Country - Belgium Current Country - Portugal
geryS2's Avatar
Garage
nice project too! will be following your thread !!
__________________
S2 's and oldtimers
geryS2 is offline   Post Tools
Unread 06-05-17, 05:40 PM   #77
80Quattro
Home Country - United Kingdom Current Country - England
80Quattro's Avatar
I've managed to put some time into this between other projects. I've got the headlining out to reupholster, at the same time I'm changing all the interior trim to black. I've painted all my existing trim which seems to have worked well, but time will tell how well it stands up to use. This is the first batch, I'm in the process of doing all the interior lights.
The make up mirror is broken and the sunvisors in general are difficult to know what to do with, I might try painting the driver's one and see how it turns out, my other thought is to have them upholstered in the headlinging fabric, I think finding a pair of RS2 ones is out of the question.
I've started to refurbish the rear brakes, the strip down took hours as someone had previously tried to remove the stainless plates by using a chisel on the bolts, I had to drill out 3 of them in the end. I'm in the process of bead blasting them, but it's very slow with only a 14cfm compressor. Until I've removed all the pistons I'm not quite sure what will be required.
The corrosion isn't too severe, but still needs some attention.
I got a pair of cast front arms that will be blasted and powder coated along with the front and rear hub carriers, I just need to get the bearings out of those.
I've also replaced the backing foam on my passenger door card, it was a horrible job to remove all the old foam, I then used a 3mm scrim foam on the back of the original material and then stuck that on the door panel. The driver's door is going the same way, but I'll leave it until the foam starts coming out!
__________________
92 Audi 80 Quattro => RS2 Saloon!
98 TVR Cerbera 4.5
63 Austin Mini Super Deluxe (turbocharged)
69 Austin Mini Cooper
71 MGB GT
75 Daimler Vanden Plas 4.2L
04 Kawasaki GPX250
96 Subaru Legacy GT-B
80Quattro is offline   Post Tools
Unread 07-05-17, 04:58 PM   #78
80Quattro
80Quattro's Avatar
Grab handles and reading lights done,
I've also done the interior light, although I might buy a genuine one as they're only 20 or so, the sunroof switch is a more difficult one as they're 50 new and only ever fitted to the D11 V8 with black headlining, if I paint it the illumination won't work and that will annoy me!
Otherwise it's just the sunvisors to deal with now.
__________________
98 TVR Cerbera 4.5
71 MGB GT
04 Kawasaki GPX250
Unread 07-05-17, 07:03 PM   #79
quattrostyle
Netherlands
quattrostyle's Avatar
Nice, the doorcard came out great
quattrostyle is offline   Post Tools
Unread 16-05-17, 08:11 PM   #80
80Quattro
80Quattro's Avatar
Time to deal with the headlining!
It took many hours just to get to that stage, it wasn't a bad job really, it's just how much has to be removed, especially with the sunroof. I would really have struggled without the workshop manual.
Most the foam came off with a wire brush
The rest I steamed off until I had this
I don't have any pictures of the progress, but eventually I had this
It's not perfect, and I have to admit I really struggle with upholstery. The biggest issue I had was that the material doesn't have much stretch so it's very hard not to get creases, especially around the sunvisor recess.
No A-pillar trims unfortunately, mine broke when I removed them, and I've had no luck in finding any.
__________________
98 TVR Cerbera 4.5
71 MGB GT
04 Kawasaki GPX250
Unread 22-05-17, 04:02 PM   #81
80Quattro
80Quattro's Avatar
The headlining is in, wasn't too bad to now I know how the sunroof goes together, this is the best picture I could manage.
I'm trying to sort out the steering wheel at the moment, I have this;
and this;
But I ordered the horn push listed on the album and I received this;
As you can see, the emblem is wrong, it's too far recessed and it's single contact so I'm not sure how it will earth.
If anyone has a picture of the rear of the correct item, or the Nardi part number, that would be a great help.
__________________
98 TVR Cerbera 4.5
71 MGB GT
04 Kawasaki GPX250
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Powered by vBulletin® Version 3.7.0
Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
DTO Garage vBulletin Plugins by Drive Thru Online, Inc.
2003-2016 S2forum.com. All Rights Reserved.
