S2Forum - The Audi S2 Community
Go Back   S2Forum - The Audi S2 Community > Technical > Suspension & Steering
Reply
Thread Tools Display Modes
Unread 09-05-17, 01:43 PM   #1
M_GORDON
Home Country - Thailand Current Country - Antarctica
M_GORDON's Avatar
How AK Top Mounts + KW v1 coilovers install
Hi friends!
Some month ago, I bought and install with my mecha friend on his workshop some KW v1 coilovers and a pair of AK Motorsport Top Mount.
My friend told me how that we must mount but I'm in doubt.
The top mounts are like those:
And here some pics
I think it's wrong I can heard some "clock" en the right side. And fronde the motorbay I can see a few of coilover inside teh TopMount.
Maybe I leave the tread? but... how install the spring cover?
THANKS A LOT GUYS!
__________________
M_GORDON is offline   Post Tools
Unread 09-05-17, 02:25 PM   #2
PeterS
United States
PeterS's Avatar
Looks like you still have the bearing from the old OEM style mount on that strut...
__________________
Peter S
1990 ErsatzS2 - Pearl/Black track toy
1991 Coupe Quattro Silver/Black(forever awaiting a 3B swap)
1991 Coupe Quattro Silver/Platinum
1991 Coupe Quattro Red/Black
1995 S6 Sedan Cashmere
1995 S6 Wagon Silver
PeterS is offline   Post Tools
Unread 09-05-17, 03:01 PM   #3
varia
Current Country - United States
Garage
indeed Mr. is right, no need for that bearing
__________________
varia is offline   Post Tools
Unread 09-05-17, 04:28 PM   #4
blux
Belgium
blux's Avatar
Yes. Your KW end where the purple plastic is. Is the bearing stuck on your coilover?
__________________
1967 fiat 500 future project
1976 audi 100 coupe S
1989 vw corrado 16V
1989 audi 90 quattro 20V sport
1994 audi RS2 project
1994 audi RS2 parts car
1995 audi RS2 project
blux is offline   Post Tools
Unread 09-05-17, 04:51 PM   #5
A1QSHIP
United States
A1QSHIP's Avatar
Quote:
Looks like the stock spacer nut is used to hold the bearing in place. I'd love to see a picture of the AK Motorsports fastener that holds the topmount to the strut.
__________________
"Nulla tenaci invia est via"
A1QSHIP is offline   Post Tools
Unread 09-05-17, 06:52 PM   #6
andy10v
Scotland
andy10v's Avatar
Garage
Quote:
Picture stolen from rxl
Quote:
Originally Posted by rxl View Post
__________________
Current-2004 350Z
Sold ABY-stock
andy10v is offline   Post Tools
Unread 09-05-17, 08:41 PM   #7
M_GORDON
M_GORDON's Avatar
yes...
And w/o the nut or the bearing or the tread; I don't know how hold the purple top from the KW; and assemble the Top Mounts
__________________
Unread 11-05-17, 06:16 AM   #8
jade
Home Country - New Zealand Current Country - Spain
jade's Avatar
Quote:
Originally Posted by M_GORDON View Post
yes...
Spring compressor ? or possible you could line it up and use a Jax to compress it into place.... it you have the adjuster backed off it should not be difficult
__________________
RS 2 580HP
jade is offline   Post Tools
Unread 11-05-17, 11:48 AM   #9
PeterS
United States
PeterS's Avatar
I believe the process is:
dis-assemble the top mount, separate top and bottom pieces, compress spring, put lower half of mount (with the spherical bearing) onto the strut, install the strut nut, decompress spring, install strut assembly with lower mount into wheel well, put the upper mount onto of the strut tower and fasten to the strut assembly/lower mount and tighten the 6 M6 bolts per AK Motorsports web page: " Notice: The top six M6 screws should be tightened using Locktite 243 at 10 Nm."
https://www.akmotorsport.net/shop/al...h-12mm-offset/
__________________
Peter S
Unread 11-05-17, 01:36 PM   #10
M_GORDON
M_GORDON's Avatar
I think it's true correct method! THANKS A LOT!!
PS. other opinion or the real true process?
On AK Motorsport they didn't say me anything
__________________
Unread 13-05-17, 06:29 AM   #11
Albert
Poland
Albert's Avatar
M_GORDON > please let me know if you need any help with TM.
Albert is offline   Post Tools
Unread 17-05-17, 12:03 PM   #12
M_GORDON
M_GORDON's Avatar
Quote:
Hi Albert
Some month ago I ask U and (I think why extrajob) you only send me a link to the page where I can buy them; but where we can't see how install properly.
Thanks if you can write the method to install them.
chears!
__________________
Unread 18-05-17, 05:28 AM   #13
Albert
Poland
Albert's Avatar
Its maybe me because I am a technician but the steps are very easy. If it seams complicated please visit a mechanic workshop to do the job
1. take out your struts and OEM top mounts
2. put the washer on the top of the struts
3. but the bigger top mount part on the top of the struts
4. slide it through the metal slot. pic
5. Use two tools to thigh-en the shock to the top mount. The top screw should be the yellow screw provided in the set (here is silver on the pic). Use 85 Nm.
6. put top part of the top mounts and the top six M6 screws should be tightened using Locktite 243 at 10 Nm.
7. you are done
Unread 19-05-17, 04:33 AM   #14
Albert
Poland
Albert's Avatar
one addition. You remove the nut form the KW and put the washer in the same place, on top bearing with top mount and on top screw. Pics bellow
Unread 24-05-17, 08:17 AM   #15
M_GORDON
M_GORDON's Avatar
HI!
Yesterday I went to the workshop to disassemble everything and assemble as you indicated.
And yes, it's very easy and looks perfectly. I don't know what my mechanic would be thinking about that day.
The problem is that I don't find the washer that was embedded in the bearing. Is very important?
Sure my mechanic lost it.
__________________
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Powered by vBulletin® Version 3.7.0
Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
DTO Garage vBulletin Plugins by Drive Thru Online, Inc.
2003-2016 S2forum.com. All Rights Reserved.
