Unread 11-02-12, 01:37 PM   #16
V6quattro
Netherlands
V6quattro's Avatar
Engine and gearbox ready to go in the car
V6quattro is offline   Post Tools
Unread 11-02-12, 02:15 PM   #17
V6quattro
Netherlands
V6quattro's Avatar
Some photo's of the fuel system.
-Aeromotive A1000 Stealth Fuel Cell
-Nuke fuel filter
-Nuke fuel rail
-Nuke fuel pressure regulator
-Stack fuel pressure gauge
-1/2IN aluminium tubing
-AN8 fittings and hoses
-Bosch EV14 870cc injectors
Unread 11-02-12, 02:18 PM   #18
hermanio
Netherlands
hermanio's Avatar
Roy, are you going to change the front wishbones too ?
5 Cylinder Freak
hermanio is offline   Post Tools
Unread 11-02-12, 03:00 PM   #19
V6quattro
Netherlands
V6quattro's Avatar
No. First make some decent horsepower. When the engine is running nice i will think about that. The car already has powerflex bushes and Koni shocks so i don't worry about that to much.
I allso have the inner tie rod bushes from bambridge which are nice!
Unread 12-02-12, 02:28 PM   #20
V6quattro
Netherlands
V6quattro's Avatar
Some photos of the electronic power steering system. Hydraulic pump is located under the car.
Unread 12-02-12, 03:08 PM   #21
s2_bo
Moderator
Home Country - United Kingdom Current Country - France
s2_bo's Avatar
Looks inserting. Any reason you chose to go electric over belt driven?
Nice inlet manifold by the way!
91 S2 coupé - RIP
98 S8 - Luxury barge
s2_bo is offline   Post Tools
Unread 12-02-12, 03:12 PM   #22
djh
Home Country - United States Current Country - United Kingdom
What did the electric system come off originally and what size pipes did you use to run the fluid to the front of the car?
djh is offline   Post Tools
Unread 12-02-12, 03:20 PM   #23
Error404
Moderator
Error404's Avatar
I wish I had patented those inner tie rod bushes now, they are popping up all over the world
Unread 12-02-12, 03:41 PM   #24
martinjs
England
Belt driven will sap a few hp. MR2 pump?
martinjs is offline   Post Tools
Unread 12-02-12, 05:40 PM   #25
V6quattro
Netherlands
V6quattro's Avatar
Its a MR2 MK2 pump yes. I chose this system because i have much more room under the bonnet now. And i didn't like the hydraulic brake booster a vacuum one is much more simple.
Unread 12-02-12, 06:32 PM   #26
V6quattro
Netherlands
V6quattro's Avatar
If i remember right it was a 12mm outside diameter steel pipe. It was rated to 200bar or so. For the return line i used the same aluminium tube as the fuel system.
Unread 13-02-12, 11:54 AM   #27
fridtjov-audirs2
Norway
Many nice picture and a wery Nice car
fridtjov-audirs2 is offline   Post Tools
Unread 13-02-12, 01:13 PM   #28
Melber
Russian Federation
Melber's Avatar
A good approach to the work!
Tell us - modified the crankcase? (photos)
Melber is offline   Post Tools
Unread 13-02-12, 07:17 PM   #29
V6quattro
Netherlands
V6quattro's Avatar
I didn't modified the crankcase. I only welded a AN10 fitting for the oil separator drain and a AN12 for the turbo oil outlet on the sump.
Unread 16-02-12, 06:17 PM   #30
V6quattro
Netherlands
V6quattro's Avatar
Some more photo's
