Unread 27-11-13, 10:36 PM   #61
Simons
Spain
Simons's Avatar
Great work mate, I like very much the jig and custom posts, looks strong and it's very important to have a good aligment, will you do the same good work as in the other project??or maybe better...the level is high
one question, what you will use to paste the roof with the body??maybe a little metal pieces welded on the body to put over there a special glue...I can wait
Simons is offline   Post Tools
Unread 27-11-13, 10:43 PM   #62
G60Rallye
Originally Posted by A1quattro View Post
you are the QUATTRO MAN , we can only dream of your garage ,your skills and perfection . great job , do you want to do my next lwb rally shell [for me] ive had it for 4 years never seem to find the timie or money , probley only take you 2 weeks to make a A1 rep
Cant see what would take the time when it doesn't even need shortened!
G60Rallye is offline   Post Tools
Unread 27-11-13, 10:45 PM   #63
G60Rallye
You are always learning so I would like to think the new shell will be far better than the first one.
Roof will be bonded and riveted on, wont happen for a good while until the cage is done.
Unread 27-11-13, 10:57 PM   #64
Simons
Spain
Simons's Avatar
Nice to hear, I will learn more
ok, to weld properly and easy the top of the cage I think...do you make the same cage that in the other, or another one upgraded??or I need to wait
Unread 28-11-13, 09:30 AM   #65
G60Rallye
Cage will have a lot more bars in it and will be more of a spaceframe.
Unread 28-11-13, 10:21 PM   #66
Simons
Spain
Simons's Avatar
All bars with the same section?
Spaceframe sounds like segurity in my head, how many whp will have??
Unread 28-11-13, 10:31 PM   #67
G60Rallye
Core of the cage will be 45 x 2.5 and the rest will be 40 x 2mm. That's what the MSA blue book states so if its going to be used in competition then that's what it must be!
Unread 29-11-13, 07:02 AM   #68
Billman
Billman's Avatar
What pipe material? Any specification? Just seamless or something more specific?
Go Holset or Go RS4
Unread 29-11-13, 11:10 AM   #69
G60Rallye
It will be T45 grade as per modern WRC cages.
Unread 30-11-13, 05:27 PM   #70
Simons
Spain
Simons's Avatar
Sounds good, we will see your good job
Unread 24-12-13, 06:54 PM   #71
G60Rallye
I have been cracking on with some more work on the car lately.
Got the last of the jig made up. Front turrets bars are now done with the same process as the rears.
I also tied up the rear panel so it can be replaced with the new carbon/ kevlar one, thanks to Andy Krinks for the rear panel.
Next up was a little work on the lathe. Top mounts for the rear turrets machined from billet. They raise the mounting point 40mm and give a flat top for using proper camber adjustable mounts. They are 3mm thick so I can weld direct to them as per the MSA regs.
Then I machined up the required 40mm spacers which locate onto the jig struts and chopped off the original mounts.
A little bit of welding and grinding and the top was done, the strut require slight massaging to get it round for the top mount.
Hoping to get a little work done over the Christmas break. Getting the scuttle/ A pillars welded back into place is the next job. Then I will move onto the rear panel and getting the roof into its proper position.
Unread 24-12-13, 10:01 PM   #72
Error404
Moderator
Error404's Avatar
Excellent workmanship as we are accustomed to on your projects Hamish
Are you planning the same to increase the suspension travel for the front strut towers and what are you planning in terms of top-mounts on the front?
Unread 24-12-13, 10:39 PM   #73
G60Rallye
I will be putting the fronts as high as they will go under the bonnet skin. I think I might struggle to get an extra 40mm even with the S1 E2 bonnet bulge but we will see. I will be fabricating the fronts so they follow the same shape as the inner arches I don't like them with a machined piece welded on, a little OCD but hey! I will be having them back to the plate that's at the back of the inner arch so it can run some good caster. Top mounts can be anything off the self with a flat plate to bolt to, I have been eying up the ones that Gaz do.
Unread 25-12-13, 03:50 AM   #74
malncol
Australia
raising the front towers has more to do with the type of strut top and if your using remote canisters with hoses out the top, this will limit the height of your top but iam sure your allready onto that,
looks awesome so far
thanks
mal
malncol is offline   Post Tools
Unread 03-01-14, 12:21 PM   #75
retropower
England
Nice work, great to see this one, good to see I'm not the only one who gets the "must improve" bug!! Will be watching keenly!!
retropower is offline   Post Tools
