Unread 02-10-14, 08:00 PM   #1
Jonas_R
Denmark
Jonas_R's Avatar
Sleeper S2 Avant +450HP
So just bought myself a 1995 Audi S2 Avant.
Plan is to go 450 HP on RS2 Turbo from IrozMOtorsport with W/M injection and keep a nice sleeper look.
450 HP Plan:
  • 3" downpipe with flex and no coupler from EFIExpress - Aquired
  • 3" Cat back exhaust from Jetex - Aquired
  • 3" cat section with free flow fake cat from Frozenboost - Aquired
  • RS2 Turbo with a billet wheel from IrozMotorsport - Done
  • Wagner Evo Intercooler - Done
  • Wagner Evo EM - Done
  • RS2 Airbox - Done
  • 630CC Siemens Injectors from EFIExpress - Done
  • Roosemotorsport hoses - Done
  • TFSI Coils - Done
  • Coil harness - Done
  • Fuel pump DW300 with 034MS drop in adaptor - Done
  • Fuel pump relay harness from EFIExpress - Acquired
  • Catch Tank from K24R - Done
Engine rebuild - Done
  • Wössner oversize pistons 81,5mm
  • Main bearings KS 77209602 STD from cs-parts.de
  • Rods sputter bearings KS 77244600 from cs-parts.de
  • Thrus washer GLYCO A124/4 from cs-parts.de
  • Top bolts REINZ 14-32049-01 from CS-parts.de
  • Bottom Reinz kit 08-29178-01
  • Integrated Engineering rods
  • Head gasket set Reinz 02-29335-01
  • 7A Head
Water injection:
  • W/M injection Aquamist HFS3 - Acquired
  • S2 Extra washer fluid bottle for W/M 893955453C - Fitted
  • AEM high pressure pump with custom bracket (mounted in front wing) - Acquired
  • Injectors to be mounted in the intercooler - Acquired
  • Hoses for w/m.
  • Small hydraulic tank 893422371A to make place for washer fluid bottle- Done
Upgrade plan for the rest of the car:
Interior:
  • RS2 Speedometer - Done
  • RS2 Aux Gauges - Acquired
  • Cabriolet leather handbrake
  • Zeitronix ZT-2 with multi gauge for data logging (TPS, RPM, MAF, MAP, IAT, FP,AFR) - Fitted (still need to connect IAT and FP)
  • Centre vent for gauge - Done
  • S-Line steering wheel - Done
Wheels:
  • Audi S6 C5 Speedline 17x8" ET35 - Currently ready to be powder coated silver.
Exterior:
  • Front and rear bumper should be painted all black in vulcan black
  • Treser black lights - Done
  • Treser middle section from Audi 90 - Aquired
Suspension:
  • H&R 29909-1 30/30lowering kit - Done
  • Bilstein B6 front dampers #34-030868 - Done
  • Bilstein B6 rear dampers #24-062121 - Done
  • RS2 upper strut bearings - Done
  • Front Snub Mount AK-motorsport - Done
  • Engine mounts from AK-motorsport - Done
  • Gearbox mounts from AK-motorsport
  • All bushes needs to be changed
Brakes:
  • 996 Calipers - Done
  • Zimmermann 323x30 - Done
  • Porsche Textar Pads - Done
Clutch:
  • Sachs sinter metal clutch - Done
  • Clutch release bearing - Done
Niggles that need to be sorted:
  • New timing belt etc - Done
  • ISV needs to be change - Done
  • Refurbish for rear calipers + new pads and dics - Done
  • New bomb from Febi #26538 - Done
  • MAF Sensor + Change pins in MAF plug - Acquired
  • Zeitronix map sensor not working, need to check boost hoses - Done
  • N75 needs to be change - Done
  • DV needs to be changed - Done
  • New banjobolt and seals for tanklid and new tanklid + gasket. - Done
  • Need to cutout in rear shocks so the spring support sits correctly. - Done
  • Fix some minor rust - Done
  • Fix light in speedometer
  • Fuel filter needs changing
Some pictures from the add:
Jonas_R is offline   Post Tools
Unread 02-10-14, 08:07 PM   #2
andy10v
Scotland
andy10v's Avatar
Nice find, that is a great colour combo!
S6 wheels will be a nice stealth touch.
Interested to see if you can crack the 400bhp on an RS2 turbo.
Have you considered a billet RS2 turbo? Apparently will do 33psi peak, and 28 to redline with 300-400rpm quicker spool.
Current-2004 350Z
andy10v is offline   Post Tools
Unread 02-10-14, 08:11 PM   #3
andy10v
Scotland
andy10v's Avatar
Iroz
http://www.irozmotorsport.com/ims-rs2-billet/
Discussion
http://www.s2forum.com/forum/showthr...ghlight=billet
VRS do a 420bhp billet rs2 turbo as well
http://www.s2forum.com/forum/showthr...&highlight=rs2
Current-2004 350Z
Unread 02-10-14, 08:29 PM   #4
Ruffiano
Home Country - Italy Current Country - United States
Ruffiano's Avatar
Tonk's input: http://www.s2forum.com/forum/showpos...&postcount=124
Ruffiano is offline   Post Tools
Unread 03-10-14, 07:57 AM   #5
Jonas_R
Denmark
Jonas_R's Avatar
I will have to look into the RS2 billet wheel
Unread 03-10-14, 08:25 AM   #6
montyrs2
montyrs2's Avatar
Interesting to see one with a cone filter. I thought generally the hot air from the exhaust etc made these a bad idea?
I'd like to fit one as should let more 5 cylinder induction out but no point is it just kills power due to hot air.
Nice looking motor
montyrs2 is offline   Post Tools
Unread 03-10-14, 12:24 PM   #7
Jonas_R
Denmark
Jonas_R's Avatar
It is a bad idea if you ask me. As soon as I get an airbox it is going off.
Unread 03-10-14, 04:08 PM   #8
fish
Home Country - United Kingdom Current Country - Sweden
fish's Avatar
I have PM,ed you mate
Audi 80 Competition -94 Daily driver
www.garaget.org/fish for more pic´s of my cars
fish is offline   Post Tools
Unread 03-10-14, 06:35 PM   #9
Henkjan
Netherlands
Henkjan's Avatar
some time ago, we tested this on a dyno: with the cone filter some 5% LESS power than with the standard airbox (RS2 spec'd S2)
Henkjan is offline   Post Tools
Unread 18-10-14, 05:49 PM   #10
Jonas_R
Denmark
Jonas_R's Avatar
Some progress
So in Denmark we have this crazy registration fee system, so in order to get number plates on an S2 Avant/Coupe you have to pay the goverment a registration fee of around 9500 euro.
However there are some loop holes, If I build the avant into a VAN, then I only have to pay a registration fee of 1500-2000 euro. Furthermore then anual road tax will be lowered from 800 euro to 500 euro. But then I can't have any passensger in the rear and I need to remove seats, seatsbelts etc.
Some pictures of the conversion of my S2 Avant in to a S2 Avant VAN:
The finish result:
Unread 18-10-14, 05:55 PM   #11
Jonas_R
Denmark
Jonas_R's Avatar
RS2 Airbox installed
Also managed to install my RS2 airbox I got from Fish.
Looks much better then that awfull cone filter, and will help on heat soak. Also discovered that the hose to the DV has split and it is missing a bolt on the heatshield at the intake pipe.
It seems my aby has the metal pipe from the 3B instead of the plastic ABY one, is that correct?
Unread 18-10-14, 06:19 PM   #12
purplelion77
Greece
purplelion77's Avatar
I didn't expect to say that for a non-standard conversion to (what according to my opinion is) one of the finest examples of 90's era Audi design and craftsmanship but... I quite fancy that! I like the attention to detail. This is one sexy van! And it seems that every alteration to the car is designed to be reversible too.
purplelion77 is offline   Post Tools
Unread 18-10-14, 06:27 PM   #13
V6quattro
Netherlands
V6quattro's Avatar
The finish result:
nice VAN!
V6quattro is offline   Post Tools
Unread 18-10-14, 06:27 PM   #14
newsh
newsh's Avatar
That's an ABY pipe, the 3B one doesn't fit with the ABY IM. There are metal and plastic versions, I thought the RS2 had the plastic one but not sure
newsh is offline   Post Tools
Unread 18-10-14, 06:30 PM   #15
rxl
Home Country - Lithuania Current Country - Germany
look at the bright side of it... you can sleep in the trunk...
rxl is offline   Post Tools
